![]() | Home > Puma (Tdci) > if it was a transit... |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6180 ![]() ![]() ![]() |
What's wrong with the allegro indicator stalks? they work, they've worked for donkeys years... covered in mud & poo. ideal!
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
In fact the Allegro stalks are one of my favourite bits - none is this tosh that looks like an Aiwa hi-fi on the end of a black pipe!
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20806 ![]() ![]() |
yeah you should try the new Focus stalks try and indicate and turn the radio on instead crappy complicated chunky things they are. no thanks
Pom, if you have only got Rust on your steps and bumper i'd be very happy...I need a new bulkhead on mine ?? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6329 ![]() ![]() ![]() |
fekete
I presume you are joking about the bulkhead ! ? what is the warranty in respect of corrosion? |
No not at all it going in to be replaced...I wish i was joking...6 years on corrosion
![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Karl is that rust in the footwell lower dash? 2.4 90 XS
mse Member Since: 06 Apr 2008 Location: UK Posts: 5097 ![]() ![]() ![]() |
After having a look at mine - when the resolved the water leak i had some rust like that - it now seems all fixed - its not a new bulkhead - its a selection of brackets attached to the bulkhead, all mine were replaced, well they are shiny steel again so if they didnt replace them the buffed them up for ages. I may go out and double check when im fitting something to it later. Thats not to say its the same for you - but it looks the same area. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Mike they are replacing the bulkhead because of the rust i've had the brackets done months ago
AS you say one is a bracket the other pic is the bulkhead rotten....Grockle this is under the dash but here is a pic of the footwell ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
it is shocking how now none visible surfaces get primer only not the top coat they used to...thats ford for you Mike
1. Transit have piezo injectors, Defender only with "coil" because they can eat lower quality fuel. 2. Transit have "under engine" and upper noise covers, Defender not (for "mud" reasons) and the engine have a lot of room around, try to park on grass and listen the engine noise from outside......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
we have just bought a 10MY 2.2TDCi transit...be good to compare - they look very different
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2469 ![]() ![]() ![]() |
and can`t handle more torque due to its rather fragile ![]() ............................................................. Earth first. Other planets later |
Waiting a deeper compare analisy with photo reportage.... ![]() ![]() IID Pro MV License |
