Home > In Car Electronics > A Bar - Lamps Fitment?
SS90
If I wanted to fit an A Bar (thinking of a Simmonites one) and a pair of Lightforce 170 lamps on to a 2015MY with air con, would i need to fit some brackets so the lamps will fit without touching the grille?
Post #368781 1st Nov 2014 5:59pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Just cut the grill, your spots will stick out in front with brackets and wont look right, I had to do that with my wipacs.
Post #368960 2nd Nov 2014 12:01pm
You'll need an A bar for sir con models, that'll help.
Then ask the clearance, I'm sure if the company wants to sell something they'll oblige. Laughing
Post #368961 2nd Nov 2014 12:09pm
K9F
Cutting the grille is an option but didn't want to cut my KBX or even my original. I opted to make my own brackets that 'picked up' on the underside mounting brackets for the A-Bar itself. Yes they do protrude beyond the A-Bar but it doesn't bother me in the slightest as I don't offroad and wanted functionality over form, I then fitted a small square of high density foam between the lights and grille for extra stability .
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #368974 2nd Nov 2014 1:07pm
HansT
Sweden 2004 Defender 110 Td5 SW Belize Green
I did not like the idea of cutting the grille so I also made brackets to move the lights forward. To avoid vibration the brackets are extra heavy duty so no other support is needed. The cable runs inside the a-bar.
Post #369032 2nd Nov 2014 5:08pm
rallysteve
Flat dog a-bar on ours with cibie oscars without needing to modify brackets or cut the grille. 02' 110 TD5 Double Cab Rebuild Thread
Post #369033 2nd Nov 2014 5:10pm
SS90
Thanks guys, good idea regarding the brackets! Thumbs Up I've not seen the Flat Dog A Bars will have a look.
Post #369154 3rd Nov 2014 1:34am
MartinK
I've got the Flat Dog one on my (non-aircon) Defender:
I'm sure you could move the brackets forwards enough Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #369174 3rd Nov 2014 10:23am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
anyone fitted a steel ac a bar to one fitted with a svx grill? another job to do on mine when time lets me.
Post #369192 3rd Nov 2014 12:52pm
K9F
Brackets MKII
I had originally manufactured a set of aluminium alloy brackets that picked up on the OEM A-Bar bolts to mount my Lightforce 240 XGT spotlamps. These brackets had served me well for the last 6 years. They could have been a little more robust perhaps?
A few weeks ago I had the misfortune of having some toe rag try to steal the lights. In their frustration to try and overcome the anti-tamper proof securing bolts they decided that brute force would perhaps give them what they wanted and they attempted to twist the lights off. Thankfully they didn't succeed.
Decided to upgrade the brackets and a quick word with the fabricators at work and a scrappy diagram with measurements and I now have the MKII version made from 3mm stainless steel. Bit of polishing required and along with my forthcoming driving light upgrade that'll be next weekend's jobs.
Post #417721 20th Apr 2015 8:53pm
K9F
Finished work early this morning and rather than wake the household decided to fit the new Lighforce spotlamp brackets. Job off my list for the weekend.
Post #418310 23rd Apr 2015 9:45am
Froogle-Yorkshireman
2010 Defender 110 Puma 2.4 USW Stornoway Grey
Smart! upgrade Mal Thumbs Up Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #420067 29th Apr 2015 11:52pm
