![]() | Home > Maintenance & Modifications > Breathing easier - added air intake |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
The more expensive is our LHD kit! This is different to the RHD kit as there the heater is on the opposite side.
http://nakatanenga-tours.de/shop/article_S...%2520AL%26 http://nakatanenga-tours.de/shop/article_O...DOAITD4%26 The RHD kits will be online soon for EUR 80.- less WANTED: SII or SIII in max 1.5k |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
I'm developing my own kit. Test fitted the initial prototype grill this evening.
![]() ![]() Click image to enlarge http://defender90xs.blogspot.co.uk/ |
H3nry Member Since: 08 Jan 2014 Location: Heathrow Posts: 134 ![]() ![]() |
Hi Mark...can we see more of what's been done?
Hi Henry,
No other pictures at the moment but I'll be doing a write up on it when it's finished. I'm still ironing out some of the finer details. The back plate is machined and I am waiting on a new piece of 90mm pipe to connect to the silicon hosing. If any one is interested I can get additional parts made up. http://defender90xs.blogspot.co.uk/ |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
Watching this tread with interest as the air box and propeller mod made a noticeable difference, as did removing the center silencer. I fancy a pipe to the wing space below the KBX wing top vent to the bottom of the air filter box will be interested to hear what you guys think of the difference in performance DEFENDER 90 TDCI XS,
Finally got my intake installed ![]() Very pleased with the results. 90mm 2-ply silicone ducting (Rated to 325 degrees). ![]() Click image to enlarge CNC cut adhesive gaskets: ![]() Click image to enlarge Powder coated CNC'd aluminium plates and flange: ![]() Click image to enlarge Flange being fitted: ![]() Click image to enlarge Outer grille fitted: ![]() Click image to enlarge ![]() Click image to enlarge http://defender90xs.blogspot.co.uk/ |
Very nicely done!
jocklandjohn Member Since: 16 Sep 2016 Location: Highlands Posts: 62 ![]() ![]() ![]() |
I did this too. Not too expensive but works fine.
Parts: Grill & flange http://www.ebay.co.uk/itm/320998533769?_tr...EBIDX%3AIT Y heater pipe (Eberspacher) http://www.ebay.co.uk/itm/321300294709?_tr...EBIDX%3AIT Scoop/cover to keep water out http://www.ebay.co.uk/itm/Plastics-4-Perfo...0994249799 ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
