![]() | Home > Puma (Tdci) > 2013 Puma 2.2 loud hissing and loss of power |
Do a search under 'intercooler hose/recall'.....The threads there will lead you onto others such as.....
![]() http://www.defender2.net/forum/topic21673.html http://www.defender2.net/forum/topic20804.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
sookoon Member Since: 02 Nov 2014 Location: South Florida Posts: 41 ![]() ![]() |
Thanks K9F. But I was hoping for a 'how-to' since I'll likely have to do this myself... I included an image of the engine bay, if anyone can help indicate which hoses are the likely culprit... Thanks,
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
nice place to live, I'm sure someone will be along very soon to help you out, cant you get it done by LR under warranty DEFENDER 90 TDCI XS,
Yeah, but this seems simple enough for me to do it myself, with a little helpful nudge from seasoned Defender owners...
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 627 ![]() ![]() ![]() |
This diagram shows the air distribution within the engine bay:
![]() Click image to enlarge Hose 6 is the one that leaked on mine. It popped off on the motorway and I managed to put it back on again and tighten up the jubilee clip. It came off another 5 times before I got to replace it. I didn't bother with Land Rover's solutions (dealer - yes, we've fixed it - it just popped off again) or a different pipe that wears through and bought a set of silicone hoses from BAS (sponsor on here) and used a Mikalor clamp to hold it in place. Comparison of standard hoses and BAS hoses: ![]() Click image to enlarge View into engine bay (left hand side as you stand in front of the car facing into the engine bay) where hose 6 connects at the part that popped off, with new hose and new Mikalor clamp. ![]() Click image to enlarge Not sure ifthese hoses are a direct replacement for MY13, but I'm sure someone on here will know. Or try and get Land Rover to fix under warranty, there was a recall (I got my phone call about this last week - about 1 year after I fixed the problem myself). |
Marvelous!! Thanks for the kind help.
Interesting - how do you think that got damaged?
The more common issue is as mentioned above with the longer hose fouling on the steering column. There is an official LR recall to add a lower support bracket to stop the two parts touching. Might be worth you checking with your dealer. |
but I'll continue feeling under this hose, to see if there is any trauma or rubbing.
I'll have to wait until the silicone hoses arrive from the UK.
