![]() | Home > Td5 > Weeping TD5 is driving me mad!! |
NickH Member Since: 02 Nov 2014 Location: Halifax Posts: 204 ![]() ![]() ![]() |
Hi
Strange one that, I have only ever fitted Td5 rocker gaskets dry or with a bit of grease to hold it in place. Sometimes using sealer can act as lubricant for the gasket allowing the half moon to be pushed out by crankcase pressure easier than if it was dry. Dunno if that helps , just my experience. ![]() |
Super7 Member Since: 05 Feb 2014 Location: South Bucks. Posts: 136 ![]() ![]() ![]() |
Thanks for the reply Nick
![]() When I first fitted each gasket they were dry the first time. This time I refitted the gasket with sealant yesterday and it has not been run until today so it's had a day to cure. Dave |
Hi Dave
Thats just blown my idea out of the window then ![]() If its sealed like you have done then nothing should escape, maybe crankcase pressure needs checking into, usually I would expect more symptoms if the pressure was too high though. Hairline crack in cover maybe ? Sorry I cant be more help mate. |
Ha, all ideas appreciated as I'm fast running out of things to try next!
![]() I did think about replacing the cover now that you mention it. It looks ok though, no dents to marks on the sealing face. Saying that though I've also put sealant on both sides of the gasket, so any slight imperfections on the cover should be sealed. Bloody thing!! ![]() |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Have you got the top hat washer/spacer fittings present in all the holes? Are you overtightening the bolts? 02' 110 TD5 Double Cab Rebuild Thread
Yep, all top hat spacers present - not over tightened just nipped up
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Are you sure it's the cam cover gasket ? The fuel pressure regulator is in the same area and is well known to leak and fuel runs down the block picking up crud on the way and drips off the engine black and looking like oil. Just a thought. 2005 Td5 90 XS
Steve |
Hi Lou
Yes I'm pretty sure that's where it's leaking from, underneath the half moon is moist and puddles on the corner of the head / cam carrier join and runs down the block. I forgot to mention I've also replaced the fuel pressure regulator o rings and that doesn't seem to leak. ![]() |
Thought I’d update the thread..
With the gasket in place I smeared a bit of silicone around the edge of the half moon and it seems to have stopped the leak. Next time I take it apart I’ll make sure this rear corner has enough silicone on it. Dave |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Replace the PCV as its probably blocked.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5972 ![]() ![]() ![]() |
I have the same issue on mine, it weeps. I have tried gen LR gasket, sealant, no sealant, non gen LR gasket and it always leaks at the half moon and also the seal above glow plug area.
Where is the PCV thing you refer to? I have tried blowing into the rocker breather and that appears fine 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
The PCV valve is the plastic thing connected to the breather hose on the rocker cover. I replaced mine and it didn't make any difference (to the weeping) although some people say it should be a service item. They're quite cheap so it might be an idea to replace it anyway if you've tried everything else.
To stop mine leaking I put a bit of silicone on my finger and wiped it around the edge of the half moon. Next time I take the rocker cover off I'll clean it up and do it properly. Dave |
double post
How many miles are on the engine? Are the bolts and spacer/washers in good condition?
