Home > Wheels & Tyres > Wheel Studs - Standard or Long
Cuthbert
From MY-2014 onwards is it the same length of wheel studs that are fitted at the factory, irrespective of whether you have standard of HD steel wheel rims fitted by the factory?
There have been some discussion as to whether current models need to retro-fit 60mm extended wheel studs (FRC 7577) if changing to a set of HD Wolf Rims. Also views expressed elsewhere about having wheel nuts that appear not fully engaged.
Definitive answer appreciated.
Post #368836 1st Nov 2014 9:18pm
Mountain_man
Wales
My friend visited the other day in the brand new 130 Fire tenders they have had delivered at his station. They run the Wolf HD rims with standard studs. The nuts sit about 1 mm proud of the end of the Stud. This is normal and as they come from LR Special Vehicles so I wouldn't lose too much sleep over it. Look at it another way. You have 5 nuts with 20mm of thread each = 100mm of thread. On the HD wheels you only have 95mm of thread. Is it worth changing studs for another 5mm of thread?
Post #368842 1st Nov 2014 9:31pm
66north
I've owned a few 130s, the oldest being 1997 and none of them were fitted with what is commonly referred to as long wheelstuds. As above, if it's good enough for Land Rover then you don't need to waste money on longer wheelstuds
Post #368848 1st Nov 2014 9:50pm
66north
Post #368850 1st Nov 2014 9:51pm
ericvv
Already lived through 6 winters with original HD Wolf wheels supplied by LR on same wheel studs as my dual finish wheels. If longer would be needed, Land Rover surely would have said so. They can not afford to compromise on safety for accessories they themselves offer.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #368870 1st Nov 2014 10:28pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
If they have a line on the end of the stud they are ok for hd rims if not then they will need to be changed 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #368871 1st Nov 2014 10:29pm
Cuthbert
Thanks chaps - Nice clear definitive statements!
Anyone bought a Defender this year with HD wheels and would like to comment? Belt and braces and all that?
Post #369062 2nd Nov 2014 6:33pm
Retroanaconda
I've seen three new Defenders with HD wheels through work, all have had the standard studs which leave a mm or so proud as mentioned above.
If it's good enough for Land Rover then it's good enough for me Smile
Post #369096 2nd Nov 2014 8:08pm
Mine's a MY13 and came with the "standard" length wheel studs.
Reading more about the topic, I came across an acticle/posting that suggested that the longer studs were only meant for the earlier vehicles with rear drum brakes. The drum was a lot thicker than the discs and therefore you could not fit a HD wheel on with the standard studs. Hence the longer studs were meant to be used with the drum brakes.
Not sure if this is true, but it does seem to fit the facts, especially since LR don't seem to use the longer studs with any disc braked vehicle now.
Post #369703 5th Nov 2014 1:14pm
Grouse
The British Army fit Wolfs to drum braked vehicles on Std Studs and merely torque them up more
Post #369745 5th Nov 2014 4:49pm
That is consistent with the Puma WSM which gives the following torques:-
Steel wheels 100Nm/80lbft
Alloy wheels 130Nm/96lbft
Heavy duty wheels 170Nm/125lbft
It is interesting also that the note "Wheel nuts must be tightened by diagonal selection" (ie the way I have been brought up always to tighten such things) is applied but only to the standard steel wheels.
Post #369749 5th Nov 2014 5:06pm
Do they still have vehicles with drum brakes?
Post #369754 5th Nov 2014 5:20pm
Grouse
Yes 100%
Post #369812 5th Nov 2014 9:19pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Not sure if this is true, but it does seem to fit the facts, especially since LR don't seem to use the longer studs with any disc braked vehicle now.[/quote]
Exactly this. And photo evidence always helps.
Post #369952 6th Nov 2014 5:24pm
