![]() | Home > Maintenance & Modifications > Heavy duty crimper....? |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
I'm planning to install a twin battery system and want to crimp the cables myself.
I've seen this on eBay and wondered if anyone has experience of using it...good/bad..? eBay Item No. 221553111158 Any other recommendations..? Cheers Simon |
dlks151 Member Since: 30 Jun 2014 Location: Auchinloch Posts: 67 ![]() ![]() |
I bought one a few years ago.
Owning an electrical contracting business I was keen to see what the quality was like when compared to a Cembre, Klauke or Kompress for which you are paying the best part of £1k with all the dies. There is no comparison!! The dies are soft, the seals on the tool are poor, the compressive strength is rubbish. If you want to make a few DIY crimps it'll do you a job for a short time, but its not a professional tool. |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
http://www.ebay.co.uk/itm/Laser-5284-Batte...33715bbab5
I use this one. Do the crimp, then fill with solder, it ain't goin' nowhere. It wasn't me! |
You do not need a hydraulic one for your purposes. Whilst very cheap it will undoubtedly do the job but sledgehammer and nut come to mind. Klauke make excellent crimp tools but at a premium. I have this set at home but expensive. Try to find a non hydraulic one as it is unecessary.
http://uk.rs-online.com/web/p/crimp-terminal-kits/3982264/ http://uk.farnell.com/klauke-textron/k05/crimp-tool/dp/3349202 If you were nearer you'd be very welcome to a loaner. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
http://www.vehicle-wiring-products.eu/sect...ping-tools
Almost forgot about this lot. It wasn't me! |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
http://www.vehicle-wiring-products.eu/prod...crimp-tool
The one i have been using this week,, a few years old, and still does the job well California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Thanks for the offer... ![]() Cheers Simon |
Found another option, seems to have good reviews and price is right for a DIY job.
Crimper Crimping Tool Ratched Crimp Hand Electrician Pliers Wire Cable 6-50mm² by Jago Crimper Crimping Tool Ratched Crimp Hand Electrician Pliers Wire Cable 6-50mm² by Jago Link: http://www.amazon.co.uk/dp/B0090XX0I2 Cheers Simon |
Seems a good choice with some excellent reviews. At that price and feedback you cannot really go wrong.
![]() Treat every day as if it is your last....one day you will be right!! |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
I just order up some gear from Mobilecentre regarding a dual battery system too hang a 95 Nat Luna fridge etc. Anyhow order up one of them Chinese hydraulic $70 crimpers. I will report back, however it's only got too work a few times for it to pay for itself. I paid more for pair of Knipex pliers! I must agree it would not compare to a Cabac Cembre Klauke.
I ordered this one, so will see how it goes. Cheers Simon |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 186 ![]() ![]() |
I had one just like that but orange...................... ![]() |
I brought one of these as it was cheap and to see if it was much good ( already had manual ones ), brought on a auction and even cheaper and its been good used it quite a lot , done 12v battery leads , 3ph workshop electrics , lent it out and it came back in one piece Last edited by munch90 on 31st Oct 2014 12:27pm. Edited 1 time in total |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
When I fitted a winch to my previous Defender I didn't have a large enough crimper so I improvised (owning a Defender makes this second nature) I used a piece of angle iron and a vice by using the point of the angle iron to force a V along the length of the terminal when compressed in the vice. This made the connection tight enough that I couldn't pull it off and never gave a problem when in use. 2005 Td5 90 XS
Steve |
