Home > Maintenance & Modifications > Truck light query
Fullfat
1999 Defender 90 Td5 HT Rioja Red
Truck light query
Hi I have a set of truck lights fitted and when my sidelights are on the led position lights are on as well as the main led lights is this correct? I thought just the position lights came on on their own.
If this is incorrect what would be the issue, they were just plug and play and i used the mud stuff piggy back harness.
Thanks
Post #367116 25th Oct 2014 6:16pm
munch90
guessing you still got the dim dip connected ?
think all you need to do is disconnect the resister
Post #367130 25th Oct 2014 7:00pm
Fullfat
Munch90, where do I locate the resistor? Sorry limited knowledge on electrical Embarassed
Post #367143 25th Oct 2014 7:43pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I believe it's under the drivers side front wing Thumbs Up
Post #367146 25th Oct 2014 7:54pm
munch90
if its the same as others it's a gold coloured thing about 2 inches long with fins on it riveted to a bracket and a wire out each end going to one plug , just unplug it
Post #367147 25th Oct 2014 7:59pm
Fullfat
Thank you all will give it a go tomorrow,
Thanks
Post #367156 25th Oct 2014 8:49pm
VeeTee
Netherlands
http://www.defender2.net/forum/post314514.html
Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #367160 25th Oct 2014 9:00pm
Fullfat
Have checked this morning nothing there , mine is a td5 1999 is the location the same ?
Post #367221 26th Oct 2014 12:24pm
munch90
did it have dim dip fitted , did the headlights come on dim with the sidelights on (with ign on ) before
a few searches show it right under the wing half way between bottom of aerial and wing vent blank on o/s wing tucked up the top
Post #367223 26th Oct 2014 12:43pm
munch90
any luck sorting it?
Post #367269 26th Oct 2014 5:23pm
Fullfat
Hi munch90 no luck there definitely isn't a resistor fitted in that location, I can trace the wiring to and from the lights and they don't go to a resistor.
I'm not sure if the lights came on with the sidelights with the old lights.
Not sure where that leaves me ?
Thanks for the help.
Post #367283 26th Oct 2014 6:05pm
munch90
only other thing to look for is a headlight control unit , think its a pink relay in fuse box or in dash somewhere
part no YWC10050 ?
resistor could be by brake master cyl looking at another forum
Post #367285 26th Oct 2014 6:08pm
Fullfat
Ok will have another go tomorrow, dark now Sad
Post #367297 26th Oct 2014 6:35pm
munch90
might be worth refitting old lights to see if you have dim dip , bit of mucking about I know
Post #367300 26th Oct 2014 6:51pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
i had this on my truck and changed the relay in the foot well for a non dim dip version 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #367322 26th Oct 2014 7:58pm
