![]() | Home > Maintenance & Modifications > 4x round drl's |
URBAN TRUCK Member Since: 24 Jan 2014 Location: Milton Keynes Posts: 150 ![]() ![]() ![]() |
Hi there , it comes with all the instruction but if you struggle it should be no more than 30 minutes work from any capable garage.
Regards Simon UT |
Rudski Member Since: 13 Jul 2014 Location: Lake District Posts: 141 ![]() |
Thanks simon
Could be one of the first mods, decisions,decisions . I also like the main headlights is there a massive difference in the amount of light given off from them? Can see a small fortune being spent on this vehicle ![]() |
Haha ... It's a slippery slope rudski ...
There are a few main headlight options we do . You are welcome to call and discuss ![]() |
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 ![]() ![]() |
UT,
Would it be possible to have the drl's built into the bumper as you normally do with them dimming as the headlights are on and then also having the Razer led driving lights installed using a secondary light switch from the cabin? If that makes sense? Then you would have DRLs for normal use and the option of a brighter light if needed with the led driving lights? Hope I'm not being overly simple...! James |
No problem at all James , the drls automatically dim down when the lights are switched on .
The lazers (or any other light) can be put on a second switch and we use an oe switch the 2 on it so you don't have an ugly aftermarket switch in the cabin. Like below pic : ![]() |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
How much are those switches please? as i could do with one in mine fro my rear work light as i had a after market one fitted from new by the dealer?
Stu |
50 odd quid
alfajock Member Since: 12 Jan 2011 Location: Bedfordshire Posts: 227 ![]() ![]() ![]() |
Hi Simon Is there any update on the mixed DRL / Driving light version. I'm in Woburn so I'd be interested if you can supply and fit (I'm lazy) Thanks Alan Fully Restored 89 110 CSW V8 CLS 350 CDI for the sensible stuff |
Apologies Alan,
I'm still trying to add driving lights to the range, for now though, It's just DRLs I'm afraid . Regards Simon |
Fair enough - thanks for the quick response anyway Simon Fully Restored 89 110 CSW V8
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5135 ![]() ![]() ![]() |
Most machine shops will cut you the holes if you supply them with a template. Had mine done at machine shop becuase I have a stainless steel bumper, they charged me £20.00 for a perfect job.
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
What thickness are the bumpers you use Simon ? I'm after one sort of 5mm thick is that something you can do with 4 drls
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
