![]() | Home > Maintenance & Modifications > 4x round drl's |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2660 ![]() ![]() |
gonna make up a copy of the kahn bumper while I'm on my next 4 month trip, getting a load of stuff colour coordinated for the car so will get the bumper done also,
thinking about going with this kit http://www.outbound4x4.co.uk/shop/exterior...bumper-kit any one any other thoughts on good round drl's? Kahn one for any interested - retail was like £1300 last time i checked hence DIY ![]() Click image to enlarge |
URBAN TRUCK Member Since: 24 Jan 2014 Location: Milton Keynes Posts: 150 ![]() ![]() ![]() |
Hi,
The DRL's are great quality and look fantastic with the recess, We have the DIY Kits available in our store and all you need is a 79mm metal hole saw. If you don't fancy the install I have prebuilt recess DRL bumpers on the way in about 7-10 days time using these exact lights. Price are as follows : Single DRL DIY Pack (Contains 2 lights and fittings) - £99 + VAT Double DRL DIY Pack (Contains 2 lights and fittings) - £198 + VAT If you want the prebuilt version (about 7-10 days time) Single DRL Bumper £199 + VAT Double DRL Bumper £299 + VAT Here is an example of 2 lights installed : ![]() Click image to enlarge |
666PXX Member Since: 05 Mar 2014 Location: Berkhamsted Posts: 113 ![]() ![]() ![]() |
The lights look great, but are a
I Agree 666PXX … The fitting isn't easy at all and even more so for a double DRL because there isn't much space and the cuts have to be mm perfect.
Thats why we are getting the pre built bumpers with 2 and 4 lights pre installed. Regards Simon UT |
well I didn't think it was much trouble fitting / cutting the holes , you got a template for marking etc , like I said cut holes slowly with cutting oil
got a cutter from swcrewfix |
Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280 ![]() ![]() |
Are there any options to fit driving lamps rather than DRLs in the recess' ?
I currently have a pair of Cibie Oscars on an A-bar but am starting to think that it looks little dated and like the 'clean' lines of the UT machines (in particular) but still want additional high beam lighting. |
I was thinking of adding in Driving lights.
Just sent an email to our supplier to see if we can do a mix . back to you soon. Regards Simon UT |
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 ![]() ![]() |
I'd be interested in a bumper with DRL and driving lights to aid full beam!
Ideally would like to remove bumper, get it galvanised and then re-fit once UT had done all fitting etc first, would this be possible? James |
Oops double tap on iPad...
defender4 Member Since: 22 Jun 2011 Location: South East London Posts: 411 ![]() ![]() ![]() |
Rigid Industries driving lights set into bumper from IRB
not a fan of the above, my led bar covers my extra lighting needs so these would be a drl only for me, and as my current bumper is starting to flake on the bottom i might as well try drilling it myself then having it powder coated if it doesn't work out ill just buy a bumper from urban.
Sure, I was replying to the Mean Green and Bristol 90XS queries/comments about driving lights in the bumper.
boode Member Since: 11 Apr 2012 Location: Devon Posts: 436 ![]() ![]() ![]() |
Picture for Mean Green and Bristol 90XS
Rigid Industries Dually D2 driving lights and Amber Fog lights recessed in a D44 bumper DLRs are within side lights ![]() Click image to enlarge |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
i like the round drls they look good but would want them built into a heavy duty stainless bumper coated in black ?
![]() 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
