![]() | Home > Maintenance & Modifications > Warrior Samurai S9500HS winch |
| zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669
Wow, not much response. What I've read is impressive, so I find it weird no-one has any info on it.
Anyway, in an attempt to still get some feedback, I just upped this topic |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Have not used the Warrior winches myself so can not make any personal recommendations one way or another on them.
Speak/email Chris or Darren at the Electric winch shop http://www.electricwinchshop.co.uk/ Tell them exactly what your intended use is be it hard line winch challenge, pay and play, self recovery, pulling boat onto trailer etc. Have been with them when they have been advising customers and yes they were mentioning things like the seals, single/double etc and how waterproof things are. So try contacting Chris and see what he says. Brendan |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
My advice on winches is always talk to David Bowyer, if it's about winches he knows it.
http://www.dborc.co.uk/goodwinch/ I think from memory of talking to him, the bars are too close to the drum on that winch and that causes it to self destruct. But it was a conversation a long time ago.. Andy |
| John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 374
I have the 12,000 lbs one in a discreet bumper on my D3. I have used this in anger to recover a very stuck Toyota in a snow drift, and worked without any issues. I have found it great for occasional use, but not sure how it would fair under constant use. I've never had a problem with mine.
Hope that helps. Cheers John |
I understand the 12000lbs is exactly the same except for a different gearing.
Personally I prefer a 9500lbs as I'd rather break the winch then bend the chassis. In any case, very helpfull reply, as I prefer personal experience above hearsay. How long was it fitted when you used it? |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8484
i also vote for Goodwinch TDS winches, in my experience they are the only lowlines that work after lots of neglect and infrequent use - which is the main killer of winches. they pull well and have very low current draw for what they pull comparably.
in comparison the OE fit Warn XDtis at work have to be stripped and cleaned out every other month due to water ingress! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| pjw4233 Member Since: 30 Nov 2009 Location: Lake District & Cheshire Posts: 273
I have the 12000 model and very impressed with it.
Used it for recovery, self recovery and mainly for pulling trees and timber. So far been very reliable and pulls extremely well. For the price they take a lot of beating, and they are re badged Champion winches that were well respected. |
| Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492
Another vote for goodwinch. The speed of them is incredible and only matched by far more expensive winches. It may not sound much but it does make a huge difference. I also had to strip mine down after 3 years of being dunked into very deep water, there was no sign whatsoever of any water ingress.
1994 Def 90 300tdi |
