Home > Td5 > Headlamp levellers
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
Headlamp levellers
Does anyone know if the wiring loom form these are likely to be present in a 2005 hard top defender?
If so what does the headlamp to motor connector look like and is there a decent installation instruction sheet anywhere.
Thanks
Peter.
BTW disklokuk have offered a 10% discount for the disklok for land rover owners via code lro14
For my post to them showing this
http://forum.landrovernet.com/showthread.p...r-Defender
Post #365820 20th Oct 2014 8:35am
I believe that it is present in the standard TD5 wing harnesses, along with the wiring for the alarm BBUS in the n/s harness. Certainly the latter connector was later deleted from Puma harneses fitted to vehicles not supplied with a BBUS from the factiry, so to retro fit a BBUS to a Puma it is necessary to obtain a TD5 n/s wing harness.
If I recall correctly the connector is a rectangular shell with three receptacles.
Whether or not the dash wiring is present is another matter, and one upon which I cannot advise.
Post #365824 20th Oct 2014 8:56am
PaulMc
Microcat lists different harnesses for 'headlamp levelling' and 'basic' specifications.
If your vehicle doesn't already have the wiring for headlamp levelling, it can easily be added.
I posted details of the connectors required, here - http://forums.lr4x4.com/index.php?showtopic=88285&p=760762
. Paul.
Post #365840 20th Oct 2014 10:56am
rallysteve
Our 02' 110 has the wiring for the levelling in place behind the lamps (plugged into a dummy connector) and also the connector behind the dash for the switch. I was looking to add it onto ours but didn't come across any reasonable priced bowls/motors.
Post #365892 20th Oct 2014 2:46pm
