![]() | Home > Td5 > td5 egr removal benefits if any |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 419 ![]() ![]() ![]() |
Well I finally got round to removing the egr and fitting an alive blanking kit. My verdict? I SHOULD HAVE DONE IT SOONER, PERIOD. Acceleration is more refined, smoother. I'm well pleased
![]() ![]() Click image to enlarge |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
Now imagine what state you intercooler, hoses and inlet manifold are in.
True, but that oily gunk has come from the crankcase breather not the exhaust.
It is highly likely that the turbo, intercooler, and MAF and MAP sensors are generously coated in the same stuff. |
dancerdave Member Since: 14 Mar 2014 Location: N Ireland Posts: 80 ![]() ![]() ![]() |
Just done mine along with dumping the centre exhaust box and first impressions are more lively and smoother. Its still not overly noisy which I was worried about
It will be oily till the egr valve and like the picture after that.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Neil5489 Member Since: 19 Dec 2013 Location: Cheshire Posts: 87 ![]() ![]() |
One of the best mods you can do. Clean the boost pressure sensor at the same time
You can always stick a filter in the crankcase breather line.
![]() Just do a search under 'Provent'.... ![]() Treat every day as if it is your last....one day you will be right!! |
Kevzeboy Member Since: 19 Jul 2014 Location: Cumbria Posts: 88 ![]() ![]() ![]() |
According to a chap I know who works for Cummins Diesel in R and D told me EGR gasses are actually slightly corrosive.
That's enough evidence to get shot for me! I took the EGR and cat off my TD5 when I had one and it made the engine run more smoothly with a couple of MPG in my favour! Kevin |
sherifsalem Member Since: 02 Jan 2013 Location: Porto Posts: 96 ![]() ![]() ![]() |
Removing the EGR is not enough, on td5 you will need a filter on the crankcase like Provent 200, otherwise you still get the oily vapor allthourgh the air inlet circuit.
I did it and I very satisfied, no oil vapor deposits on the tubes or intercooler, you can see pic on my blog if you want Thegippo.wordpress.com Happy Travel www.thegippo.wordpress.com |
You can check more info in this French vid
http://wp.me/pFe4N-6V Happy Travel www.thegippo.wordpress.com |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Does the Provent allow it to run cleaner? Will it help exhaust smoking and emissions? I've seen them mentioned but don't know too much about them
What i can confirm to you Lambley is that the circuit is in fact clean now no oil deposits on the tubes from the Turbo to the intercooler , the intercooler itself is clean and finally from Intercooler to Air Inlet manifold.
The provent infact retains these vapors to a very high degree, i purge the filter every 5000-10000 km and you can see liquid oil draining filling a cup. There is no mistake that those vapors are going to air inlet manifold and together with recirculating gases from EGR would actually be slowly killing your engine performance(i found black thick TAR like in the inlet) in the combustion chamber. I dont think the filter does anything on emissions or black smoke. Happy Travel www.thegippo.wordpress.com |
Ok, thanks, I'll look into fitting one.
Seeing is believing....
![]() Click image to enlarge This is what comes out from the crankcase after 5000km in Morocco.. Happy Travel www.thegippo.wordpress.com |
