Home > Maintenance & Modifications > removing egr cooler
Caterham
removing egr cooler
I think I know the answer to this but it would be really helpful to have a heads up first if I've got it wrong.
I plan to remove the egr cooler tomorrow and I believe (hope) I know where all the fixing points are;
2 studs / nuts where it joins the exhaust manifold another on the corner of the engine near the egr valve and onto the valve itself.
sound about right or is there more behind the engine?
many thanks.
Post #363852 11th Oct 2014 10:05pm
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Can you take some photos when you do it ? I still have to do mine but didn't know how so left it in place. Photo and a how to would be appreciated Thumbs Up Thumbs Up Thumbs Up
Post #363855 11th Oct 2014 10:53pm
SupraAyf
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Here we go sir.
All bolts are torqued at 23Nm Wink
 - Andrew -
Post #363885 12th Oct 2014 9:30am
Fifth Horseman
Probably a bit late,
There are two bolts from the cooler to the bracket and then one bolt to the block
[URL=][/URL]
Don't forget the clips around the cooler that hold the coolant pipes.
[URL=][/URL]
Good luck, it looks like access is a bitch.
Post #363925 12th Oct 2014 3:03pm
Why are you removing it?
Post #363936 12th Oct 2014 4:40pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I'm removing the cooling element to my 3.2 as its not doing anything 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #363966 12th Oct 2014 6:39pm
Caterham
Kind of a bit late......
I didn't need to completely remove the cooler although I might soon.
I needed to disconnect it to fit my egr plate near the exhaust manifold. What a pain the bum....I managed to drop a bolt down by the starter motor and the bracket so I'll be popping out in a bit to try and recover them... any suggestions on how?
Post #363970 12th Oct 2014 6:53pm
Try something magnetic?
Post #363972 12th Oct 2014 6:55pm
big steve
Iv always fitted the plates exhaust side Thumbs Up
Steve 2015 2.2 tdci hardtop xs
Post #363979 12th Oct 2014 7:21pm
munch90
if you had got a plate that fits egr end ( in between cooler and egr valve ) you could have used a blank with slotted holes , just loosen bolts slot plate in and tighten bolts 5 min job
Post #363987 12th Oct 2014 7:54pm
Caterham
That'll be an......IF. Very Happy
Only I didn't.
So now have one bolt and one bracket in between engine and alternator
Sad
Getting alternator out looks nigh on impossible....will they find their own way out and I just buy a new bracket?
Post #364003 12th Oct 2014 8:39pm
munch90
oh not quite gone to plan then
have you got a bolt snapped now?
have you got it disabled ?
if you blank off without you should get the mil light on
if your dropping things down by the starter , you should disconnect the battery
Post #364005 12th Oct 2014 8:45pm
Caterham
No nothing broke thank god.
Foolishly I undid all 3 bolts 1 holding bracket in place (which I didn't need to) plus the 2 from cooler to bracket. Bracket and bolt dropped Big Cry
All back together otherwise and gonna go for test drive shortly.
Post #364007 12th Oct 2014 8:50pm
Caterham
I was rather worried about the battery thing but not much I can do about it now.
egr is disabled and egr cooler at exhaust end now blanked and all appears to be working well.
Just need to see about either removing the cooler all together or replacing the bracket the supports the cooler off the engine near the egr valve.
Post #364059 13th Oct 2014 8:33am
Caterham
sorry forgot to say.....thanks very much SupraAyf. very helpful.
not sure where you got the info but that's a far better set of diagrams than I could find.
Post #364060 13th Oct 2014 8:37am
