![]() | Home > Maintenance & Modifications > Double DIN Fascia Issues |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Hope you get it fixed James
![]() Might be worth speaking to Matt at FCX as he has the double din in his demonstrator! I'll be interested in the outcome as I'm considering the same setup with Apple Carplay for my 110 Cheers John 2014 110 2.2TDCi XS Station wagon - GONE 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE Last edited by jomara on 11th Oct 2014 11:12pm. Edited 1 time in total |
URBAN TRUCK Member Since: 24 Jan 2014 Location: Milton Keynes Posts: 150 ![]() ![]() ![]() |
Hi Bristol 90XS …
We fit a couple of these each week and the finish should be factory. It shouldn't hang out like that .. They just need to put the cables in carefully and most importantly heat up the heater pipes at the back to bend them out of the way slightly .. This gives you enough room for the unit to go in nicely and the front clips to bite without being under so much strain. Should be like these ones we have done : ![]() Click image to enlarge ![]() Click image to enlarge |
As Simon has said above, the Double DIN facia should look factory.
We remove the metal bracket that is welded to the cross bar behind as this causes clearance issues. It's not a job for the faint hearted, I'm sure I did a write up at some point, do a search on this forum. (Sorry, I'm out and on my iPhone otherwise I'd do it for you) |
Also , Take out the metal bracket in the back, . Needless of experience, its a pig of a job if you haven't done one before. I think its better left to companies that Only do Defender rather than car audio over all.
If you need any other help , feel free to email . Regards Simon UT |
We are away from base at the moment but as Matt and UT says finish should look factory fit.
We have supplied many of these fascias without major issues. You may/maynot have to extend some of the wiring for the switches but it should look good? A good audio company should be able to fit one without issue. As an aside we do not recommend the piano gloss version as we fel they show up scratches too readily in comparison to the Matt black version. Brendan |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Did they supply as well as fit the part?
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 ![]() ![]() |
Thanks Matt, Simon and Brendan, appreciate the replies.
@Matt - I was hoping you could have done this earlier in the year when I had my re-map done, but shame you're not doing it any more. They did compliment the full range of leather though and they particularly liked the FCX comp cubby - which now has a third USB socket directly to the back of the stereo! They said they moved the pipes after heating them, but didn't remove a bracket... Maybe that is it? Will forward them this post after a day or two! Any one any ideas on the clock? @borderterrier - yes they supplied and fitted the fascia. As I said really pleased apart from the fitting of the fascia... James |
They need to put that right mate, you cant live with it like that. Its a shoddy job at best. Have you paid them yet?
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
from what i remember when i did mine, you need to take the metal bracket out (its there to centralize/support the back of the single din) as it gets in the way of the back of the double din unit.
r1ch3d Member Since: 24 Dec 2020 Location: Victoria Posts: 4 ![]() ![]() |
I know this is a double din fascia thread, however there seems to be some experienced posters in here
Has anyone had experience installing a single din touch screen yet? I bought the Sony XAV-AV8000 and I need to source a mounting bracket for each side of the dash unit to lock it in place, but I can only find the double din fascia kits online for the Defender. I have an MY14 - Hoping someone can point me in the right direction Thanks in advance |
