![]() | Home > Puma (Tdci) > Wiring converter for Exmoor heated seats into 110 XS loom ? |
if your asking what the capictor is for in a relay , its to stop voltage spikes happenning - like if you got a ecu controling a relay as the relay switchs off the energy field in the coil in the relay collapses it can send a spike down the wiring and maybe damage something sensitive (maybe a led sorry dont know )
dont think it really matters which way wiring goes on load side , its the same load carried in the same bit of relay , but for the future if you have a problem and want to test the wiring etc it will get confusing as its the other way round if you wire it wrong etc wiring on switching side needs to be round right way if you need to make use of the capictor |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Reckon it must be the LED in the switch, elements in a Heated Seat wouldn't care about a spike.
Just wanted a 2nd opinion as I'm never confident. I'll also swap the pins for sanity, like stuff to be 'normal' Last edited by Tiger on 10th Oct 2014 8:34am. Edited 1 time in total |
Elements couldn't send a reverse spike could they?
They are just a big resistor? They wouldn't 'Discharge' would they? |
no , relay coil your talking small electomagnetic field
heating element is really just a resistive wire thats made to heat up and its not wound in a coil guess really its just like a bulb element but doesnt glow (hopefully ![]() |
sraosha Member Since: 30 Apr 2015 Location: Dar es Salaam Posts: 29 ![]() ![]() |
Hi, Does anybody know where to source these Puma switches? Apart from ridiculously priced heater switches north of 40 £? I have two dead switches on my county edition Puma, left and right of the AC switch and would like to replace them with my own installation, e.g. for work lights. There has to be a way to get those OEM Defender switches, no? Or do I need to destroy the optics with Carlingtons? Thanks! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
Any Land Rover main dealer, or parts seller will stock them.
Part number = YUF500150LNF http://www.rimmerbros.co.uk/Item--i-YUF500150LNF ![]() Click image to enlarge Her are a few more - http://www.paddockspares.com/yuf500150lnf-switch-assy.html http://www.lrseries.com/shop/product/listi...-ASSY.html http://www.brit-car.co.uk/product.php/1718..._def_2007_ http://www.lrdirect.com/YUF500150LNF-Switch/ . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Paul, wow, thank you so much for the quick reply. Had read some forum entries so far and searched the dealers but so far only stumbled upon the 50 £ light switches. Are they 10x the price of the ones you mentioned because they are directly switched, without relay? Maybe.
Will thus order the YUF500150LNF plus a relay, then scratch off the 'hot seat' and print an icon on some adhesive foil, then transfer onto switch. Not 100 % original look but close I hope. Also appreciate your wiring diagrams, of which I have seen a number on this forum. Very helpful. Best, |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
Hi Paul, would you know where i could get male MQS connectors to suit the vehicle loom to plug into the seats? RS and VWP dont seem to help (me!?) much on that front, google not great either but its probably the driver. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
JST,
Try these.... http://stores.ebay.co.uk/3waycomponents?_trksid=p2047675.l2563 http://www.dingocroft.co.uk/acatalog/Electrical_Miscellany.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
PM sent ![]() . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
