![]() | Home > Technical > Centre dash lights not working |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20975 ![]() ![]() |
Most likely that the bukbs need replacing as they've blown at the end of their life.
That's a lot of bulbs to blow all at the same time.
Are the switches illuminated ? |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 813 ![]() ![]() ![]() |
No - I'm 99% sure all the centre dash (apart from radio) is in darkness - that includes all the switches, and clock.
(I'll check again later on the school run). So yes, seems unlikely to be failed bulbs. Switches themselves functioning normally, btw. |
Mine has done the same but I haven't got round to checking the feeds to the backs of the swithes yet, Mine coincided with me delving about in there so I have probably dislodged a connector block or disturbed an earth, just need to get my head back into the electrickery theme and not the adjust it with a big hammer theme before I get back in there!
Yes, it's been over a year at least since I had a rummage around with the radio out, so I can't quite remember how the connectors worked, but still seems odd that just the illumination would go off, and not the functions?
If it's not a fuse, then I guess I'm just going to have to open it up and have another fiddle - when I get the time (probably next summer!) |
wobble_hd Member Since: 26 Feb 2008 Location: Norway Posts: 18 ![]() |
Hello
I had the same problem last winter and it was the main switch. Also the high beam was affected. Bought a new one but before fitting I took out the old one and used my wife's nail file and polished the contacts. Vips it worked again. Please dont tell my wife.... Good luck to you. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
The only Bulbs so to speak in the dash centre are cigar lighter illumination and hazard light switch, the rest are led and can't really fail, just my 5p worth
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Assuming that it's a td5 of course
If it is my truck you assume is a TD5 then the answer is Yes.
Please do try to take out the main switch and connect the 3 cables together. If the light comes on then you have found the problem. If not then I'm wrong. M |
