![]() | Home > Technical > Tracing an electrical fault on blower |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Isolate the blower itself if possible and switch it on with the ignition on. If the fuse still blows you know the issue lies with the circuitry and not the blower itself. Thereafter find a convenient point isolate the circuitry halfway and try again. Quickest way to find the culprit area but you will need a few fuses.
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006
99.9 times out of 100 it's the motor itself or the wiring where it passes into the heater box mate
| DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 271
Is there a best way to isolate the circuitry to test?
Am I also correct in that the fan speed sliders act as the earth? I'll check out to see how much the motors are, too. Thank you both. |
Pull fuse 45 rated at 30 amps and disconnect the black earth cable from the blower switch the circuitry will be isolated. Looking at the diagrams you should then have the following resistance values from the blower switch cables (cables disconnected from switch) these are your blower speed resistor values...
From the brown wire to the blue wire on the blower switch 0.45 ohms. From the brown wire to the red wire 0.55 ohms. From the blue wire to the red wire 1 ohm. You can then carry out any further insulation resistance checks as necessary. Apologies if this is an 'egg sucking' exercise but may point you in the correct direction perhaps? Good luck. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 8th Oct 2014 2:43pm. Edited 1 time in total |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Also check the resistors pack Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
Dgardel resistors pack checks are written above....the 0.45 0.55 bit.
K9F,
Thanks: the help given by you is what makes this forum so great to less knowledgable folk like me. Absolutely not teaching me to suck eggs and bizarrely looking forward to fixing the blower next week...... My last ask: does anyone just happen to know if it is it a case of dismantling the dash to disconnect the black earth cable? Cheers Rob |
DC101,
You're welcome. Dgardel who posted above produced a comprehensive source of useful information. Follow the link below and contained therein are a complete set of wiring diagrams.' Workshop public' is the icon you need to head for. Don't get over excited about the 'Blower' icon that should read 'Bowler' from the photos........Happy hunting and good luck.... http://api.viglink.com/api/click?format=go...7269580318 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| All times are GMT |
