Home > Td5 > Centrifugal oil filter help
Derrickthedefender
United Kingdom 2004 Defender 90 Td5 SW Zambezi Silver
So I just checked my TD5 centrifugal oil filter as part of a service and found that one of the bolts has sheared of all threads in the housing, so it is only held in place with one filter.... Any ideas on remedying this?? A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Yes the name for my 90 is Derrick!
Post #362785 7th Oct 2014 8:30am
You can put a bolt all the way through and a nut on the other side.. It's a common one, that.
That's if I understand the you got the original bolt out?
Post #362787 7th Oct 2014 8:40am
rallysteve
I put a helicoil in ours to repair the thread having stripped out of one hole. It did however run for about 2weeks with only one bolt tight.
Post #362831 7th Oct 2014 12:50pm
Derrickthedefender
Ah nice one thanks guys, didn't realise it was so easy! A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Post #362903 7th Oct 2014 4:50pm
g-mack
best : helicoil
works: long bolt with nut under it
quick bodge: cable tie
note: if it pops off while driving it can pour oil out without you knowing. ask me how I know Very Happy My 109 thread
my youtube channel
Post #362905 7th Oct 2014 4:54pm
Derrickthedefender
Do you guys know what size bolt it is for a helicoil, don't get the m4, m3 etc... A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Post #362908 7th Oct 2014 4:59pm
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Depends what size helicoil you put in there Laughing
Post #362920 7th Oct 2014 5:36pm
Fatboy Slim
Wales
Standard is M6x1.I've got a spare housing here I'm thinking of doing a 'service exchange' style helicoil service for forum members if anyone is interested? ?
Post #362925 7th Oct 2014 5:53pm
munch90
tap it out 1/4 unf , no drilling needed , 1/4 unf is a small amount bigger then m6 , 2 min job
use a 1/4 unf bolts , 7/16 af head or use 11mm socket spanner
helicoils are ok to repair , but using on a bolt that you will need to get regulaurly to service they can bind up and rip the outer thread out then its even more trouble , not always but this is possible !
personally I wouldn't helicoil it
time serts are better for bolts that need to come out again , but can expensive for a kit and need to drill
Post #362941 7th Oct 2014 6:54pm
Derrickthedefender
thanks for your replies, im quite the rookie with these sorts, with tapping out for a new bolt, is that relatively easy? A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Post #363916 12th Oct 2014 12:35pm
munch90
if you use a 1/4 unf tap there is no drilling , just wind tap in to hole where thread has stripped , may need long tap holder or find a 1/4 drive 12 sided socket need the tap square end fits , wind in straight normally thing when tapping is couple of turns in one turn out , couple of turns in one out , until your right in
sounds more complicated than it is , but you could do both holes in under 5 mins
you may have to open the holes up in the top cover slightly for the extra sized bolt , opened up to 1/4 or 6-7mm with drill
Post #363927 12th Oct 2014 3:16pm
tasr12
England 2002 Defender 110 Td5 CSW Zambezi Silver
Stripped thread would be easy?!!
I've changed mine this evening except the outer most bolt sheered! That meant the filter housing came off filter is changed and is back on but only held on by one bolt.
Has anyone done this and how would you recommend I go about removing the remainder of the bolt that is still threaded within the housing...drill out? Fairly annoyed as the rest of the service went well for my first time on the TD5 and I can now hear the centrifugal filter 'wind down' on switching off which I couldn't beforehand! 2002 110 CSW TD5, Zambezi Silver
1995 110 CSW 300TDi - SOLD
Post #451198 1st Sep 2015 9:11pm
Derrickthedefender
I ended up drilling through the holes and putting longer bolts in, haven't had any drama since and that was about 8 months ago! A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Post #451211 1st Sep 2015 9:44pm
tasr12
Thanks.
Having just been out and had another frustrated look under torch light that is going to be my only option. I'm just concerned that the 'remainder' of the bolt may cause issues inside the thread as I drill through
I can't think of any clever way to get it out though.
Did you re-tap or use bolts and nuts?
Cheers. 2002 110 CSW TD5, Zambezi Silver
Post #451225 1st Sep 2015 10:23pm
JWL
Have you looked to see if it is actualy a bit of bolt stuck in there? It may just be that the bottom of the hole is full of years of accumulated dirt and dross that when poked through will just fall out as it is a through drilling on the rotor housing.
Post #451244 1st Sep 2015 11:13pm
