|  | Home > Puma (Tdci) > Defender rear tail lights and rear wiper erratic behaviour |
| John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106      |
 Hi lads, I have an odd problem with my 2007 110 H/T. The rear lights are all working but not as they should be   the indicators stop working if you put Yor foot on the brake and stay on,and the parking lights will flash if you put the indicator on, and to top it all off the rear wiper has stopped working or when I put it on the tail lights come on? I can't see any obvious fault in the loom as I stripped it back to the y piece at the back of the rear crossmember. It's driving me nuts   Any ideas? Cheers John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible | ||
|  6th Oct 2014 7:11pm |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | bad earth 100% I'd say | ||
|  6th Oct 2014 7:13pm |
| John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106      | Lord that was quick! Where would it be earthed? I only ask because on the lorry it's bolted to the chassis directly behind the battery box.
 Fair play and thanks for the prompt reply  For those who understand, no explanation is needed... For those who do not understand, no explanation is possible | ||
|  6th Oct 2014 7:15pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | Does indeed sound like an earthing fault. | ||
|  6th Oct 2014 7:19pm |
| Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339      | If you mean this connector then yes, thats the earth for the rear lights etc.
 [URL=]  [/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated   | ||
|  6th Oct 2014 9:11pm |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | that's the one
 thanks | ||
|  6th Oct 2014 9:19pm |
| John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106      | Cheers, I'll get under it in the morning and check it out.
 Thanks a million  For those who understand, no explanation is needed... For those who do not understand, no explanation is possible | ||
|  6th Oct 2014 9:37pm |
| John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106      | Spot on lads, everything is back working fine! The bold was a small bit loose    Thanks again Cheers John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible | ||
|  7th Oct 2014 7:18pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    |   Just goes to show what odd things can happen with an earth faulty. | ||
|  7th Oct 2014 7:30pm |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | that's good then , nice to have a easy fix once in a while and not the dramas that defender ownership can bring    | ||
|  7th Oct 2014 7:32pm |
| John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106      | I'm still in shock that it wa that simple!    For those who understand, no explanation is needed... For those who do not understand, no explanation is possible | ||
|  7th Oct 2014 7:42pm |
| Posting Rules
