Home > Maintenance & Modifications > Another booring leak post
Eduardo
In my defense I can say that I used the search tool to see if something popup but nothing useful appears.
I have a severe leakage (when I said severe means more than 200 cc in a 4 hrs of not too heavy rain) from the rubber seal that is betweeen the windscreen frame and the frame where the vent was located. The seal in the picture circled in red.
There is some sealant that can help to stop it without take out all the frames?
Cheers! Eduardo
Post #361428 1st Oct 2014 2:40pm
K9F
Eduardo,
Are you sure it's not the defunct hingeblocks? Mine was leaking through there, three bolts and they come off. That would be a quick check for starters. Sikaflex29i is the best sealant in my book.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #361434 1st Oct 2014 3:15pm
Eduardo
Thanks KF9
The seal appear absolutely wet from inside and when I use a hose to try it, appear to comming from there. For this reason is my first supect. But I will check that also.
Cheers! Eduardo
Post #361439 1st Oct 2014 3:31pm
K9F
Good luck Eduardo. I do know people have sealed the same seal below the windscreen before. Thumbs Up
They recommend the same sealant too. Thumbs Up
http://www.defender2.net/forum/topic28654....khead+seal If you go through life with your head in the sand....all people will see is an ar5e!!
Post #361441 1st Oct 2014 3:37pm
jhnstap
United Kingdom 2005 Defender 90 Td5 XS CSW Tonga Green
As K9 Thumbs Up
Sikaflex to the back of the hinge blocks cured it-such a quick fix as well I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine
Post #361453 1st Oct 2014 4:32pm
Anderzander
Just to state the obvious - mine was leaking in the same spot and then I noticed that the drainage gap behind the binge block was blocked up - I cleared that out and it cured the leak.
Post #361468 1st Oct 2014 5:31pm
ZeDefender
Another alternative (my favourite) is butyl tape. It sticks to anything for as long as you want and seals 100%. You just make a long "sausage" and push it into the gap. I've used it for everything over the years and, unlike some sealants, it never peels off. Our caravan is 27 years old and you can still dig it out of the cracks, roll it around a bit and seal up other areas Thumbs Up Tell someone you love them today because life is short.
Post #361473 1st Oct 2014 6:17pm
silky16v
England 2001 Defender 90 Td5 X-Tech LE Blenheim Silver
are you sure its the bulk head seal?
i suspect its the vent flap seals that are letting water in?
Post #361486 1st Oct 2014 7:03pm
Eduardo
Thanks to all
Thumbs Up Thumbs Up Eduardo
Post #361487 1st Oct 2014 7:03pm
gilarion
door seal where it is forced to bend round the angle of the bulkhead just below the top hinge could also be the culprit, water can quickly seep in there and it drips off the door hinge plastic cover into the footwell, check to see if the door seal is a tight fit round that angle.
Post #361492 1st Oct 2014 7:16pm
K9F
silky16v wrote:
are you sure its the bulk head seal? i suspect its the vent flap seals that are letting water in?
It's a Puma no vent flaps! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #361527 1st Oct 2014 8:36pm
jimbob7
For something different I used Captain Tolleys creeping crack cure and a small syringe to apply it directly onto the foam seal which soaked it up like a sponge,also did the Wipac, nas lights Rolling Eyes ,fake hinges and everything else that looks like it might leak,lol.tbh, I dont really have any noticible leaks,but the foam seal did look as tho summut had bean eating it Shocked . Pov.spec,ftw. 2006, 110,TD5.
Post #361581 1st Oct 2014 11:28pm
ZeDefender
Photo is misleading Whistle Tell someone you love them today because life is short.
Post #361601 2nd Oct 2014 7:12am
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
leak in heck.
Only my opinion.
Buy looks like the windscreen hinge has been off at some point to paint it black.
Will assume whoever put it back did not use mastic sealant where the bolts go through. Took mine off an early 90 once and someone had liberally applied tiger seal or similar in these holes with the bolts. Not sure if same on later Defenders, but if hingres not bolted down tight enough this will leak too. If it were me I have would take windscreen surround out, and replace roof rubber, bulkhead seal, and door rubbers. As putting mastic in is assuming something is perished and is continuing to perish. This is the area that needs to be water tight partly for electrics drivers side but also look on old knackered bulkheads and you will see the rust holes it eventually
creates.
But hey you probably have loads of money and won't keep it that long.
Regards
Peter.
Post #361606 2nd Oct 2014 7:42am
K9F
The picture is of a TD5 and I think it was only used for representation purposes as Eduardo has a 110 Stornoway Grey? The hinge blocks and door hinges on certain models were supplied painted black originally.
What on Earth has money and the OP's intention of keeping the vehicle got to do with it? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #361613 2nd Oct 2014 8:20am
