Home > Technical > 2 stroke oil
Page 8 of 10 <12345678910>
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
First90 wrote:
On to my second tank with 2so added. All I can say is WOW!! what a difference. So smooth and quiet.
My 2010 90 was so noisy and clattery and from reading these threads I am guessing it was injector related. But since adding the 2 stroke it is exactly how I thought a modern diesel would sound and this apparent smoothness makes it much nicer to drive. It seems to rev higher more easily too but I am not sure if that is just because it sounds like I am not strangling a cat.
I am loving it!
+1
When I put some in I thought there was probably a difference but you never know what the placebo effect is.
But when madam next got in, she asked what on earth I had done to the engine , it was so quiet.
She is not a woman known for her mechanical sensitivity.
Post #236557 18th May 2013 11:26am
landybehr
Sorry if I�ve missed when/where it�s been answered.
What about 2SO and the DPF. I read contradictory things elsewhere. Some say that 2SO will add Sulphur-Ash which blocks the DPF. Others say that combustion is cleaner with 2SO so in the end the DPF benefits. The latter thesis seems to be based on "gut feeling" rather than measurements. And if Sulphur were not to be considered , I wouldn�t have to buy that 5W30-C1 oil for it.
Anyone driving a post-�12MY TD4 with 2SO and without DPF blocking (mileage?).
Post #236583 18th May 2013 1:21pm
keith
Yep , 2.2 110 XS with 12000 miles . Making no differance to the DPF and had no smoke or soot or running problems . The DPF is doing its job and running a burn cycle at 880 degrees every 350 miles for me . Can I feel a differance with the 2SO ? Not really , except the cost at 350ml every tankfull . Unless its beneficial to the engine then i don't see it doing any other positive things , eg : fuel economy , emitions ,
Post #236605 18th May 2013 4:06pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Ive stopped using 2SO in my TD5 and now using the millers diesel max stuff. Its never ran so well!
Post #236607 18th May 2013 4:13pm
rossy
I think different additives suit different motors. I used that stuff religiously on my previous VW engined motor and I was still getting running issues eg frequent gunged up MAP sensor. Then 2SO cured everything miraculously. I regard 2 stroke now as a kind of automotive All-Bran - stops everything sticking to the sides Laughing
Post #236701 18th May 2013 9:23pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
Same here. I'm really impressed with the Millers stuff Thumbs Up
Post #237038 19th May 2013 10:03pm
First90
2010 Defender 90 Puma 2.4 HT Alpine White
Same thing, we were driving on the highway at 100kph and actually having a conversation (unfortunately for me!) when she said the sound proofing I installed was working really well. Only thing is that the sound proofing is still in the packet...
2 stroke doesn't do much for the whine of BFG KM2's though so the sound proofing will still go in.
Post #237058 19th May 2013 11:28pm
jst
So any more views to add with more time having past on the benefits or not of adding 2SO?
those that saw an initial change still using it? had any problems with it? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #360603 27th Sep 2014 9:00pm
LR90XS2011
I've used quality 2SO in my BM for 62k miles from new it has a DPF no ill effects so far in fact the at each MOT they cant even measure the emissions DEFENDER 90 TDCI XS,
Post #360611 27th Sep 2014 9:21pm
munch90
everyone I got to try it are all reporting good things , and are all continuing to use it
never known any additive to have as good results as 2t
Post #360614 27th Sep 2014 9:25pm
munch90
just out of interest what oil do you use?
Post #360916 29th Sep 2014 7:19am
jst
cheers Guys, yes which 2SO are you using? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #360938 29th Sep 2014 10:44am
K9F
K9F wrote:
I have recently started using Millers diesel treatment too, Thumbs Up
That was from a post nearly five years ago. I still use Millers to this day and it has become 'second nature' each fill up to shove some in the tank. I obviously must have rated it too but have been using it so long now I've forgotten why?
Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #360939 29th Sep 2014 10:54am
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Please forgive me for being ignorant but i am not sure if i have an injector problem or not really heavy on juice 20 mpg ( 2.5 td 90 with defender 200tdi fitted ) so assuming i have would 2 stroke help solve this or am i better buying a new set of injectors and going from there Confused Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #361000 29th Sep 2014 4:44pm
K9F
Graham, I may be wrong but if it runs well with no undue noise or smoke personally I wouldn't worry. Most modern Defenders return on average (for those that drive 'normally') 24-27mpg. Taking the age and boots that you have fitted to your nice looking truck as stated don't worry too much.
Also if it ain't broke don't fix it. Perhaps a little Millers for a few tankfulls and then see how you fair at worst, or, just leave well alone.
Thumbs Up Thumbs Up
Post #361006 29th Sep 2014 5:07pm
