Home > My Defender > My first 90
Page 2 of 2 <12
CLCraig
United Kingdom 2015 Defender 90 Puma 2.2 HT Stornoway Grey
It was so nice to be treated so well really can't praise them enough. Thinking the lovely cubby box from FCX with the lights inside. Like the raised height so can use it as a arm rest. A KBX front grille and headlight surround in black but not sure yet and probably upgrade to led lights Smile but have plenty of time to play
Post #360788 28th Sep 2014 4:13pm
I keep my aerial constantly down, then again I don't use the radio.....
Far to prone to getting snapped off! Especially around here. Whistle
Post #360790 28th Sep 2014 4:16pm
CLCraig
That's what I was thinking to be honest. Seems to be a bug magnet with the upright windscreen lol
Post #360792 28th Sep 2014 4:24pm
K9F
JustStarting wrote:
Nice the dealers take the time to make it special for you.......Have you got anything planned for him?
Weekend away or candlelit dinner for two perhaps? Rolling with laughter Bow down Rolling with laughter
CLCraig wrote:
Stupid question but do you run with your aerial up or down as mine was down all the way home and had perfect reception.
Laughing Doesn't really matter as my top portion wore out and at full extent it used to go down on it's own. If you've got good reception with it down you've no requirement to extend and tempt some toe rag to bend or snap it. Great looking truck.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #360796 28th Sep 2014 4:41pm
CLCraig
Haha dinner for two sounds lovely Rolling with laughter thank you big change from my previous car.
Post #360800 28th Sep 2014 5:00pm
Or three if you include the Defender. Rolling with laughter
Post #360808 28th Sep 2014 5:28pm
CLCraig
Bow down Dont want to offend him
Post #360852 28th Sep 2014 7:24pm
CLCraig
So King Kong experienced his first spout of rain today and all appears dry so Thumbs Up however when looking around the seat base I noticed a white foam looking pad between the seat base and trim beneath the door line. This pad seems out of alignment on the drivers side compared to the passenger could someone tell me if this is a defender trait or is it likely to be a problem many thanks in advance Craig.
Drivers side
Passengers side
Post #362157 4th Oct 2014 2:46pm
nitram17
hi craig mine is the same! i think its coming from the lower door seal front edge of door...gave it a squeeze and water came gushing out......i have no idea how to fix it but sprayed the door innards with bilt juice.....rust magnet me thinks!
Post #369852 5th Nov 2014 10:50pm
Cuthbert
If you are referring to the foam 'packing' strip - it's only there to fill the gap and from what I've seen seems to be a sort of double sided sticky tape with a foam filling. Probably costs JLR about £1.00 for 1000 metres and appears to fall out/sag out of some joins almost as soon as it is inserted at the factory.
You might like to get a windscreen scraper out (now that frosty mornings are upon us) and reposition it - if it offends thy eye?
Post #369872 6th Nov 2014 12:15am
Page 2 of 2 <12
