![]() | Home > Maintenance & Modifications > Bulkhead repair panels |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045
Its got the point where I need to get the bulkhead repaired. A quick hunt gave me this repair section
http://www.yrmlandrover.com/epages/BT3575....ducts/001A this partly appeals to me as it would remove another water ingress and a source of draughts point on the Landy, but another part of me thinks its ok with the vents. in replacing this section, things that need removing off the top of my head Windscreen wipers Bulkhead brackets Windscreen Roof (to get the windscreen out) Washer jets. Door hinges Does the dash need removing or any other part of the dash? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
I was wondering about the spindles. Can they not just be unbolted from the outside, cut out the old bulkhead and then remove and refit without the need to remove the spindles?
The wiper motor is on the passanger side, behind a panel (prob same as a Tdi) Is the bulkhead boxed i,e is there a panel behind the dash then a gap and then the outer panel? Edit. Found this link on the YRM website http://www.yrmlandrover.com/epages/BT3575....eplacement 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2718
If you are going to the length of repair panels and the work involved it might work out easier to replace the bulkhead completely. Buy a used bare example, spend some time sorting the issues out on that and then fit 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
I'd love to replace the whole bulkhead but no workshop/garage/drive coverage.
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8494
spindles, you could do on reflection but does the new panel not need welding in along the top edge?
yes its boxed and twin layered in some places if i recall. before the bulkhead prices went through the roof i did some repair panels on one truck, soon after i did a bulkhead change on another truck, the latter was quicker! and easier. now prices have gone up so much it may be more £££ saving to do the panels but personally i would change the bulkhead. if its gone in one place chances are another will show itself before too long. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
The panel will need welding across the top and looking at the picture on YRM it looks like there are holes in the top to weld through.
At the mo, I just dont have the cash to buy a decent bulkhead, paint it and pay someone to strip the Landy down to replace the bulkhead - otherwise I would 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| All times are GMT |
