![]() | Home > Maintenance & Modifications > Cost of maintenance |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
Nothing! It's a diy job. It wasn't me!
50-60% of what a dealer would charge. Pick up the phone, that may cost you nowt!
![]() Treat every day as if it is your last....one day you will be right!! |
Shooter1 Member Since: 01 Sep 2014 Location: Bedfordshire Posts: 7 ![]() ![]() ![]() |
Already spoken to an Indipendant JLR garage, been quoted £400. Just wanted a steer weather thats reasonable.
Ozzy, I'm no DIY mechanic ! |
If you've a Puma follow the link below to all you need workshop manual, wiring diagrams etc. and if you've the time or inclination give it a go....you might surprise yourself. Alternatively find a mate with the technical acumen, cross his palm with silver and let him do it?
Quick fix......
Or ring another Independant and if the quote is the same you'll just have to shell out the £400. Price sounds about right to me, I was quoted £124 for one to be done in 2010. http://api.viglink.com/api/click?format=go...52F113CDqk If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks K9F for taking the time to respond. I trust the garage to do a great job, just wanted a second opinion. Booked it in for 30th September.
Cheers |
Nothing is more rewarding that DIY.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Had both seals and new swivels put in the back end of last year by an Indi £200.00 Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
