Home > Maintenance & Modifications > Replacement headlight harness - Highly recommended
Page 8 of 11 <123 ... 78 91011>
noworries4x4
I think I have just ordered a loom from Holland, my Dutch is crap but think I got it right. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #358766 18th Sep 2014 8:48pm
Lots of weird things can be bought in Holland - I hope you got it right! Shocked
Post #358807 18th Sep 2014 10:23pm
noworries4x4
So do I Embarassed If everything is under control you are not going fast enough.
No Worries 4X4
Post #358820 18th Sep 2014 10:59pm
Pickles
For anyone interested in a better harness, Traxide apparently do a very good one, they advertize on the Aussie forum.
If you google Traxide, you'll find them.
Pickles.
Post #358821 18th Sep 2014 11:01pm
Tiger
Before you go mad with this mod, and I've done it Very Happy
Measure the voltage at the bulb.
Mine was 14.2v with the factory loom. LR aren't that bad, just adding a relay would help prevent the switch burning out.
(Admittedly the new loom got the voltage up to a staggering 14.3v and now my headlights have been transformed from dim candle to the shining light of babylon, or I can't the difference)
Post #358822 18th Sep 2014 11:07pm
Tiger
Post #358823 18th Sep 2014 11:11pm
Tiger
Noticed a 'Glitch' or 'Feature' with my eBay special loom.
Dip works well
Main works well
Flash works well without lights on
Flash doesn't work with Dipped on (is this an MOT fail?)
Anybody else's do this?
Post #358982 19th Sep 2014 9:18pm
munch90
if the feeds to switch relays is from the oringal headlight plug then it should all work
also in your link to where your measuring the voltage between old set up and new set up the voltages will be the same as not measuring with the bulb lit up , the load the bulb takes is what gives you the voltage drop , with the bulb still connected and lit you would have seen a voltage drop of 1.5-2 volts on the old set up
Post #358983 19th Sep 2014 9:27pm
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Dip works well
Main works well
Yes if this was the cheap loom from Ebay then i had the same problem they had wired the relays wrong, Im in Spain at the moment so cant remember exactly which is wrong but im sure it was just two of the pins around the wrong way. That loom was ok as a starting point but by no means a plug and play. I brought two of the harnesses and then modified them into one really good loom and put a seperate live feed to each relay with two fuses so i have effectively isolated the circuits for both main beam and dipped beam. When you have the loom in front of you and follow the wires while looking at a pin out of the relay its really obvious which wires are wrong. Thumbs Up 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #359017 20th Sep 2014 9:09am
TD5_dan
I made reference to it in my thread here: http://www.defender2.net/forum/topic31044.html
Oh and not sure if its an MOT fail or not but its wrong and shouldnt be like that 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #359018 20th Sep 2014 9:12am
Tiger
So you changed yours to 2 x 5 pin relays, hmmmmm. Whistle
I'll look up some wiring diagrams to see what's wrong
Post #359023 20th Sep 2014 9:35am
Tiger
Right so I've been and had a look and it's not that the pins are wrong but the basic loom is incorrect in principle.
It uses a 5 pin relay to switch power between 87 & 87a when switching Dip to Main.
This works fine as it isolates each circuit on the switch, the problem is that 'Flash' activates both circuits at the same time, the ebay loom prevents this.
So basically the loom needs to be modified to 2 standard relays and the 'Main' relay needs it's own fused power source or a jumper from the Dip relay. (As per Dan Thumbs Up )
Post #359028 20th Sep 2014 10:21am
Tiger
Oh and Munch was quite right measuring the Voltage without load was silly Whistle
LR Original Loom - Now 12.7V
Upgraded Loom - Now 13.4V - Noticeably brighter even though it's just 1V(ish)
Daylight Photo / Compare & Contrast (pun intended)
Left light is New Loom / Right light is Original Loom
Post #359036 20th Sep 2014 10:40am
TD5_dan
Thats right Tiger you have reminded me and thats why i decided to put the two seperate power feeds in, there is still nothing stopping you from jumping the live across to the second relay holder but the two feeds are better. I kept the original 5 pin relays just ignored the middle pin and treated it like a 4 pin relay which works a treat Thumbs Up 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #359068 20th Sep 2014 1:33pm
excossack
When doing this mod, where do you take the extra positive feed from ? Direct from the battery or from the start feed? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #359069 20th Sep 2014 1:47pm
