Home > Puma (Tdci) > Lights Flash When Unlocking Doors Missing
HardCharger
Hi All!
I have a 2011 and before when I would lock the doors, the turn signal lights would flash three times and when you unlock the doors, the lights will flash once. Just two days ago, the lights would no longer flash when unlocking but the doors would unlock. Is this something to worry about or maybe something that is indicative of a potential problem down the road?
Thanks in advance.
Post #357918 15th Sep 2014 9:47am
K9F
Have you tried your spare fob?
http://www.defender2.net/forum/topic27153....+batteries If you go through life with your head in the sand....all people will see is an ar5e!!
Post #357926 15th Sep 2014 10:15am
HardCharger
Hi K9F,
I've only got one FOB as the guy who sold the truck to me only gave what was with the keys to bring the truck home. He forwarded the spare set of keys for the ignition and the fuel cap but no spare FOB. Been bugging him but he doesn't reply regarding that anymore. I guess he must've lost it or something. I guess I should buy another one just to be sure then.
As for the low battery, thanks for pointing me in the right direction, I will try this out and revert back with the results.
Thanks a bunch!
Post #357930 15th Sep 2014 10:25am
Laurie
You need a new battery in the fob.
It's the fob's way of telling you.
Post #357937 15th Sep 2014 10:39am
HardCharger
Thanks for the heads up, Laurie!
Will do just that before anything else wonky happens.
Post #357941 15th Sep 2014 10:43am
K9F
Slightly.... Off Topic
Potentially with regards to your spare fob, it wouldn't sit comfortably with me knowing somebody else has a spare and could drive off with yours at any time. I would insist on him sending the spare or a written explanation where it may be. 'Stolen with keys' could have serious implications from an insurance perspective and explaining you don't have the spare may not 'cut the mustard.' If you go through life with your head in the sand....all people will see is an ar5e!!
Post #357943 15th Sep 2014 10:53am
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Slightly unrelated but... I have done the alarm antenna extension mod and used to work miracles. But now the range gets smaller and smaller. And the battery is new in the fob. Don't understand. Any hint? My Land Rover doesn't have problems... it has features to keep me entertained doing DIY
Post #357999 15th Sep 2014 2:08pm
K9F
Cyber absolutely no idea? It doesn't make any sense to me. Is it the same with both fobs and are you 100% sure the batteries you fitted are good? My extension mod was done 5 years ago and it's as good today as it was then. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #358020 15th Sep 2014 3:59pm
HardCharger
Extension mod? What extension mod? I think I saw it somewhere before but cannot find it now.
Post #358125 16th Sep 2014 6:10am
CyberCharlie
https://www.defender2.net/gallery/displayi...&pos=0 My Land Rover doesn't have problems... it has features to keep me entertained doing DIY
Post #358135 16th Sep 2014 7:31am
HardCharger
Thanks CyberCharlie! That helps!
A quick update, changed out the battery in the FOB, all is now right with the world. Apparently all the symptoms were already in the manual. Silly me. Looks like I have to go through it again just to refresh!
Thanks all for the assistance and support!
Post #358149 16th Sep 2014 8:56am
CyberCharlie
Checked yesterday with both fobs... same result. brand new batteries in the fobs but the car locks/unlocks only when I am 2 mt from it max (even when I point the fob to my head... you know the "mind" trick). I will try to do the whole extension again and hope it works. My Land Rover doesn't have problems... it has features to keep me entertained doing DIY
Post #359374 22nd Sep 2014 7:11am
K9F
Cyber it sounds to me like the extension is either open circuit or perhaps shorting out somewhere. Big Cry If you go through life with your head in the sand....all people will see is an ar5e!!
Post #359379 22nd Sep 2014 7:57am
CyberCharlie
Yep, I think I shall have some quality time with my Defender over the coming weekend Smile My Land Rover doesn't have problems... it has features to keep me entertained doing DIY
Post #359391 22nd Sep 2014 9:20am
skyeplumb
Scotland 2007 Defender 110 Puma 2.4 USW Rimini Red
mine did the no flash for about a week, then went back to normal - but then it did lock me out last week with the engine running! (see other post), I hadn't tried other fobs or changing batteries or anything. gotta love LR electronics Series IIa Lightweight - Long Gone
Discovery 1 300Tdi - Sold
Defender 110 XS 07MY Utility
Post #361254 30th Sep 2014 5:11pm
