![]() | Home > Puma (Tdci) > Exhaust gasket? |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 ![]() ![]() ![]() |
No gasket on mine either - but there is no leakage..
CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5981 ![]() ![]() |
Thank you for the quick reply.
Have just spoken to parts man at local dealer, and you are correct no gasket. But it looks like mine has been blowing! But that's nothing compared to the other turbo gasket, that's really poorly. ![]() Click image to enlarge |
When I changed the turbo gasket - and had both turbo and manifold machined due to deformation - i used some exhaust sealant between the turbo and down pipe - still not leaking…
Thanks CRJ, checked the mating face on the exhaust manifold and that was slightly deformed. But an hour laying on top of the engine and an oil stone got it flat
![]() Now all back together, apart from lower cat bracket, and heat shield, then take for a test drive. Fingers crossed. Andy |
