![]() | Home > Maintenance & Modifications > Mantec wheel carrier - split rubber washer |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Think i used some o-rings to pack mine out so it didnt rattle, looks like that one has been over tightened when it was fitted causing the damage.
Pete. |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 617 ![]() ![]() ![]() |
I'll see if i can find some rubber washers. Bit stuck without a fix as i don't want to damage the piston by driving it around at the moment.
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
The same happened to ours. The carrier kept rattling on the corrugated roads in Australia, I'd tighten it up and it'd be fine for a few 100 k and then start rattling again. Eventually the washer disintegrated and I tightened it up without the washer - has worked fine and rattle free ever since !
No idea what the washer is supposed to be there for but it works fine without it in our experience ![]() |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Jim,
As Davew said, but take the piston out and coat in a heavy industrial 'open gear' grease. Then just tighten everything up. Mines lasted over 30k without a rattle now. |
All sorted. Put some lithium grease on the 'piston', placed a grommet in the bolt aperture, covered everything in ACF50 and bolted it up tight.
Not a rattle to be heard. |
