Home > Puma (Tdci) > CLUTCH JUDDER/SLIPPING
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Hi all, Over the last 3 weeks when the vehicle is cold and i am moving off in 1st gear i get a juddering for the first few metres, it does not do this when the vehicle has been driven for a while and the engine is warm.
It happens less if i rev the engine more than normal, the handbrake is working ok and is fully released,
it had a new clutch fitted under warrenty in Nov 09 by Landrover only done a couple of thousand miles since then . Any ideas ?
Post #35743 7th Jul 2010 10:13am
K9F
Doing a search under 'clutch' comes up with 279 options, have you trawled through them to see if a solution to your issue exists?
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #35747 7th Jul 2010 10:26am
