Home > Maintenance & Modifications > Cleaning CP
Cleaning CP
What do you use to clean Chequer Plating without damaging or tarnishing it?
(Non painted Aluminium CP)
Nothing abrasive should be used obviously but a brush doesn't glean it up very well.
It's not oxidisation but seems to be very ingrained dirt, not much to complain about but is annoying.
Post #357251 11th Sep 2014 2:58pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Have you tried something like Solvol Steve??
http://www.thepolishingshop.co.uk/acatalog/Bike_Cleaning.html
We use the metal polish on chrome table bases and they come up a treat Thumbs Up
John 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #357253 11th Sep 2014 3:06pm
Might try that one day. Thumbs Up
You can see what I mean here:
It's not hardly noticeable but I know it's there. Laughing
Post #357254 11th Sep 2014 3:15pm
jomara
What about something like wonder wheels or Wurth industrail cleaner? That should help shift the ingrained dirt Thumbs Up 2014 110 2.2TDCi XS Station wagon
Post #357257 11th Sep 2014 3:37pm
grumpy old git
Muc off and an old dishwashing brush could be worth a go, won't damage the paint at all.
Post #357310 11th Sep 2014 8:49pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
I redid the side steps using ACF50 after a standard wash and it seemed to come up quite well. 1970 Series 2A 88"
Post #357311 11th Sep 2014 8:55pm
wildcamper
Scotland 2008 Defender 90 Puma 2.4 HT Zermatt Silver
best thing to use is alloy wheel polish called Diamond White all the truck show boys use it it'll come up like new with not much effort brilliant stuff Thumbs Up
Post #357657 13th Sep 2014 8:31pm
Anderzander
Best thing for me was a jet wash - I've also used soapy water and a scrubbing brush. Everything else is likely to change the surface finish in someway.
Post #357658 13th Sep 2014 8:34pm
K9F
Top Tip.....
Thought I would share as it works a treat. I have over the years tried many many different products in an attempt to clean my chequerplate but have finally hit on an excellent combination.
Wonder Wheels alloy wheel cleaner, Autosol and WD40.
The sills on my Landy were particularly bad with white oxidisation like stains that wouldn't shift. Just done one side and got the other to do in a minute. Coffee break thought I'd quickly post.
Spray the chequerplate with the Wonder Wheels and get a soft nail brush and apply some Autosol and WD40 to the brush. Agitate the Wonder Wheels on the chequerplate with the brush and gently scrub. Apply more WD40 to keep the chequerplate wet as the Wonder Wheels dries quite quickly as it turns to foam. Once finished liberally spray the chequerplate with WD40 get a clean rag and wipe everything down.
I guarantee 100% you'll be happy with the end result. I am.....It's a winning combination!
**EDIT** Addition of photos....Chequerplate is over 6 years old....
Before.....
After.....
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #358406 17th Sep 2014 12:12pm
Got your PM Mal - Thanks, will read later.
Shocked
That does work well!
Post #358462 17th Sep 2014 4:35pm
K9F
OK Steve, PM is more or less same as post. It does work extremely well, gets rid of oxidisation and ingrained dirt and tar etc, and is not labour intensive. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #358474 17th Sep 2014 5:34pm
Thumbs Up Are those Entreq door seal strip you've got there? Looks like SS to me.
You've got the CP along the side just like mine does in the same place.
Post #358478 17th Sep 2014 5:43pm
K9F
They are Entreq door strips. I also made gaskets out of butyl pondliner for the chequerplate when it was taken off to fit the strips, it was amazing how much crud there was behind it. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #358479 17th Sep 2014 5:46pm
I'm guessing you've got the same in the rear too.
I fact I'm sure you have...
Something I might look into in the future.
Got to sort my trailer lighting issues out first, then MOT then a service. Banging Head Then tax.
Probably my next objective will finally be Dynamat at long last.
Post #358484 17th Sep 2014 5:52pm
K9F
Forget the Dynamat just turn the volume up. Rolling with laughter Bow down If you go through life with your head in the sand....all people will see is an ar5e!!
Post #358498 17th Sep 2014 6:46pm
