Home > Td5 > changing the bulb behind the fuel guage
Jeremy
I noticed that the fuel gauge fails to illuminate when I turn on the lights. Could someone advise me on how to replace it?
Jeremy
Post #357086 10th Sep 2014 7:28pm
kipperthedog
It is a quick and easy job.... 5 minutes. Undo the screws holding the instrument binnacle on (IIRC two each side, two on the top and two on the bottom), lift it clear of the dashboard so you can see the back of the dials and you will be able to see the bulb holder. I think it is a 286 wedge bulb (1.2 w). The left hand side binnacle screws might be a pain with the late td5 centre dash so you may need a stubby screwdriver.
Post #357116 10th Sep 2014 8:54pm
jimbob7
/\/\/\This,get the bulbs from Halfords. Pov.spec,ftw. 2006, 110,TD5.
Post #357136 10th Sep 2014 10:43pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Don't know how bad the TD5 dash lights are but the TDI is rubbish. I replaced all mine with LEDs a while back, difference is unbelievable. They seem to have disappeared off EBay at present but here is a before and after shot
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #357160 11th Sep 2014 7:07am
kipperthedog
My mistake.....there are no screws in the top of the binnacle just the sides and bottom.
Td5 bulbs are different to Tdi and the illumination is better, in fact some who have fitted LEDs have found them too bright. I haven't felt it worthwhile on my Td5.
Post #357167 11th Sep 2014 8:08am
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
My TD5 has dropped it's illumination from about 65mph upwards on the speedo. It's probably a sign and telling me if I cant see the needle (above 65mph), then I shouldn't be up there :p.
I assume the speedo is made up of 2/3 bulbs?
Cheers.
Post #357175 11th Sep 2014 8:28am
JWL
Couple of bulbs for the speedo but different to the other clocks, again easy to replace especially with some thin long nose pliers(I use a large pair of medical forceps which are excellent for the job)
I went to a decent auto electrics place in town and they sorted me out some replacements for a couple of quid.
Post #357176 11th Sep 2014 8:39am
kipperthedog
I think it is a single bulb, and I think it is a different bulb to the fuel guage and temperature guage but I am not 100% sure. I am sure it tells you in the owners manual or take the binnacle off take the bulb out and take it to a motor factor.
JWL types quicker than me....
Post #357177 11th Sep 2014 8:44am
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Cheers.
Yup, 2 same size wedge bulbs. 1998 110 300Tdi White Hard Top
Post #357180 11th Sep 2014 9:10am
Jeremy
Outstanding! I appreciate the guidance.
Post #357312 11th Sep 2014 9:11pm
Marlin.45
Wales 2007 Defender 90 Td5 SW Baltic Blue
...and if you have a Halfords trade card they almost pay you to take the bulbs away they are so cheap Very Happy 2006 TD5 90 County
1961 MF35
Post #359549 22nd Sep 2014 8:35pm
