Home > Puma (Tdci) > Rear Door Oil Measles
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Spotted that my rear door is covered with "oil measles" see pictures, looks like blowing out from exhaust, gut feeling it could be engine oil been overfilled from recent oil change at a stealers, or should I be investigating other issues?
 Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #356991 10th Sep 2014 11:17am
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
My old 200Tdi had the same. It was due to the transferbox leaking oil.
Just a thought....
Post #356992 10th Sep 2014 11:20am
limbrickh
New Zealand 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
If the measles are spread equally on the left and right side (not just around the exhaust) then I would suspect a leaking fuel tank (or release valve).
Post #356993 10th Sep 2014 11:24am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Input shaft oil seal on rear diff ??
Been there, done that Rolling Eyes
Post #356997 10th Sep 2014 11:42am
mk1collector
FPR leaking?
Post #357015 10th Sep 2014 12:48pm
Happyoldgit
To be frank you are the best place to answer your own question but it does mean actually getting underneath the vehicle and looking for leaks or signs of seepage. The last time I had something similar was coming home from a service when I found the transfer box level / filler plug had been left loose. In the past it's been things like rear diff pinion seal leakage or leaks from gearbox or crankshaft seals but trying to actually diagnose what the specific cause is in your case without having access to the vehicle is an impossibility. Steve.
http://forums.lr4x4.com
Post #357021 10th Sep 2014 1:21pm
VeeTee
Netherlands
I experienced the same after the dealer forgot to put the filler plug back on the rear diff. Shocked Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #357074 10th Sep 2014 6:21pm
Muddybigdog
Thanks all for your notes, we think the measles were to do with the air-con moisture that pours out from under the vehicle, driving down M25, M3 then M27 on a hot day sent the air-con into overdrive releasing tons of water then with the aerodynamics of a brick it caused a small vacuum sticking the moisture and dirt to the back door.
We did find a number of "rust preventing" oil leaks from back of the gearbox, grease splatter from the UJ's and engine oil spillage, nothing major but will try to get the work done under warranty.
Just to round it out, the vehicle has now caught the turbo/manifold squeal of death when under a heavy right foot, fingers crossed a Nak gasket will work its magic. Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #357642 13th Sep 2014 5:47pm
