Home > Puma (Tdci) > Difficulty putting difflock on
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
I seem to have difficulty getting my diflock on, or at least get the light indicator working.
It sometimes goes on no problem, other times it won't come on and other times the light is fading or flickering.
Not sure if the difflock is working or it's an indicator (contact) problem.
If it's the latter, what can I check? And where?
Post #356680 9th Sep 2014 7:39am
K9F
Have you had the vehicle undersealed/waxoyled? Well known to crud up the switch and give you indication issues despite the difflock still engaging/disengaging correctly.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #356687 9th Sep 2014 8:06am
zone30
No, and was in some deep water a few weeks back, so I think you got it wright.
Where/how to solve?
Post #356701 9th Sep 2014 9:23am
K9F
By removing the transmission tunnel panels and lever, there are two connectors attached to brackets a three pin one for high/low and a two pin one for difflock on/off. If water and crud has got into the difflock one it could cause your issue. There is also a sprung detent operated by the difflock lever this too can get crudded up. You could try and tackle this from below the vehicle but it will be difficult to see unless you know exactly what you are looking for and where and you will need arms longer than a gorrilla. Take the selector lever out and the transmission tunnel panel and it will become clear would be my advice.
Similar issues after going through water....
http://www.defender2.net/forum/topic21154....ock+switch
More detailed 'how it works' thread.....
http://www.defender2.net/forum/topic29669....ock+switch
Good luck... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #356736 9th Sep 2014 12:54pm
zone30
Pfff, stupid question but if it's crud that causes this because of submerging it in muddy water, can I not just try to clean it by putting a hose from below and rinse with clean water?
Post #356746 9th Sep 2014 1:41pm
schuee
I climbed underneath when my Diff Lock selector seized and hosed it out, then a liberal coating of WD40 and a couple of hours later all sorted Smile
Post #356777 9th Sep 2014 3:39pm
MartinK
You can see the linkage on this thread http://www.defender2.net/forum/topic29132.html
Easy to get at from the top...
I would use ACF50 as the lube... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #356780 9th Sep 2014 4:10pm
zone30
Because of lack of time, I'll do the rinsing first.
Later on I will disassemble the whole thing and lube it properly, but one thought: fluid or grease? If grease, will graphite do or not recommended? If fluid, I guess I need to hunt for ACF50.
Will plastic dip any eltectrical connectors as well if they are accessible to do so.
Thx guys for the great feedback. Saves me a lot of time getting it to/from a dealer.
This was probably the reason Razz
Post #356799 9th Sep 2014 5:54pm
ericvv
Post #356822 9th Sep 2014 7:34pm
