Home > In Car Electronics > Spot wiring
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Spot wiring
Does anyone know....is it possible to wire two wipac 100w spots into the main beam circuit? Ie...just tapping into it so they work with the normal full beam? Someone told me the wattage/draw (or whatever??) will melt the wiring loom?
Post #356171 6th Sep 2014 10:27pm
JWL
Sort of, wire the spots through a relay which is triggered by a feed from the high beam circuit. Have a search on this forum, there's the search button on the header at the top or just use google.
Post #356172 6th Sep 2014 10:34pm
It will blow the fuse, Censored up the switch and possibly melt the wiring.
Needs to be independently fused and relayed with a trigger tap taken from the main beam.
In other words no extra load on the Defender harness.
Post #356175 6th Sep 2014 10:52pm
Here is a diagram:
The override switch is optional and only further complicates the wiring.
You would however need a switch for roof lights to be legal.
Post #356179 6th Sep 2014 11:06pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I used a bolt on bits kit to fit my spots - wasn't worth making my own for this price: http://www.ebay.co.uk/itm/Bar-Spot-light-l...35c1c891ff
Post #357202 11th Sep 2014 11:16am
Jonno1968
Mmm nice one thanks.....is this suitable for an electronic numpty (me).
Post #357290 11th Sep 2014 7:09pm
