Home > Puma (Tdci) > Air Inlet and Dust
Page 2 of 2 <12
MK
MK wrote:
have you thought of running a hose from the air intake circuit to after the EGR valve?
why?[/quote]
wouldn`t in this way the light go off by cheating on the sensor? Puma 110" SW
Post #35596 4th Jul 2010 10:10pm
CapeLandy
South Africa
dgardel wrote:
CapeLandy wrote:
The fact that there was such a thick layer of dust in the turbo inlet and pipe makes me worried as hell.
Have you a photo of turbo inlet and turbo intake?
No I don't - It was a definate brown dust with slight oil mixture
Post #35607 5th Jul 2010 6:46am
CapeLandy
South Africa
some slightly better news.
Spoke to three indy LR mechanics today who told me not to worry and only the turbo blades if anything could be affected. They told me just to change the oil for safety and clean out the hoses.
One mechanic told me he did the same some months back to a disco that had such a badly blocked filter that it had burst open and filled the system with plenty dust.
I am supposed to check that the intake blade tips are still square and sharp.
I could only get in with my camera due to the angle and have taken these snaps below. Edges look a little rounded but the mechanic may not be farmiliar with the Puma turbo. Question
Anyone like to offer their opinion on the turbo condition?
The other snap shows the dust/oil mix in the turbo inlet elbow which I am going to clean as well as the turbo inlet as bet I can in that space.
I dropped the intercoller for a chemical wash and will change the oil and filter tomorrow and assemble everything again.
Post #35637 5th Jul 2010 3:37pm
CapeLandy
South Africa
Looking much better now. Just a little more on the blades.
Just for interest sake - anyone feel like doing a check for me.
Take off the inlet hose at the manifold and stick your finger in too see how much gunk is in the steel pipe section. (easy 10min job)
I would love to know if mine is the only one that has oil and soot in there.
Post #35640 5th Jul 2010 4:53pm
CapeLandy
South Africa
She is all back together and running ok all be it still very jerky when cold.
I am glad I took off the intake manifold as it was caked in soot. Luckily the dust and oil seemed to have only collected at the 90 degree bend and it was only dry soot from there on in.
I degreased the inside and high pressure washed it. Seals are very supple and after a wipe with wet rag and a dry I refitted them to the manifold and bolted everything up.
Filled up with some nice clean low sulphur diesel and will see how she goes this week.
Now I need to find why the diff lock lamp is not working.
I jacked her up and tested the diff lock lever and she is definately working, just the sensor. Probably some mud in the switch - will have a look see.
I had booked her in for the diff lock so I will ask them to see if the EGR is faulty and causing the jerking. It was jerking before the dust saga so I assume unrelated.
Pictures after cleaning
Post #35781 7th Jul 2010 3:30pm
dgardel
Italy
Have you changed the inlet manifold seals? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #35797 7th Jul 2010 7:55pm
spudfan
Ireland
My airfilter cover was not fitted correctly at the second service by the maindealer. It was the part under the top wing nearest the outer wing that was not fitted properly.The engine sounded very loud or somehow different. I always check everthing after a service. It is amazing what I have had to do over the years. Always check this after your service especially if it raining when you pick her up! By the way this is one of the most educational post I have seen in years-better than a Haynes manual! Hope there is no damage done but you seem to have everthing in hand. Someone should download this post and give to some of our inept maindealers. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #35798 7th Jul 2010 8:39pm
CapeLandy
South Africa
No -but they were still fine and also not available anyways in our southern part of Africa Sad
Post #35825 8th Jul 2010 8:49am
dgardel
Italy
MK wrote:
dgardel wrote:
why?
it is sufficient a little by-pass of the MAF (when the engine is under load the inlet manifold is in pressure so the air will return back)
I'm thinking about this............. Twisted Evil Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #35835 8th Jul 2010 10:10am
dgardel
Italy
in Italy too LR sell the complete manifold...........
but Ford Transit dealer, may be, sell the seals (need to check) Whistle Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #35836 8th Jul 2010 10:13am
Page 2 of 2 <12
