Home > Puma (Tdci) > Chirping noise, chatter
John110
Ireland 2007 Defender 110 Puma 2.4 HT Stornoway Grey
Hi all, my 2007 110 has developed an unusual noise from the engine bay, it's not the turbo or the belt and doesn't affect power or performance and has no particular pattern! I'm just worried that it'll lead to something more serious.
Anyone experienced anything similar? And advice would be greatfully appreciated.
John For those who understand, no explanation is needed...
For those who do not understand, no explanation is possible
Post #355771 4th Sep 2014 10:36pm
landy andy
Could this be the gasket between turbo and exhaust manifold?
Andy
Post #355780 4th Sep 2014 11:22pm
schuee
I had a chirping / chattering noise and it was the EGR valve, also when turning engine off EGR would screach instead of the chukka chukka sound.
Also could it be the old heat shield rattle?
http://www.defender2.net/forum/post74812.html
Post #355828 5th Sep 2014 9:57am
John110
Thanks for the replies, it's not a gasket, must be the egr valve. Is it a common fault?
Post #355938 5th Sep 2014 8:10pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I had a chirping noise from my Disco 3 recently, more particularly at tickover, it turned out to be the auxiliary belt tensioner, the pivot bearing was badly worn causing the two parts of the casing to rub together as the slight irregularities of the belt made it vibrate.
Post #355941 5th Sep 2014 8:23pm
david mitchell
Ireland 2003 Defender 90 Td5 HT Epsom Green
So john, you have decided not to sell then?
Post #355974 5th Sep 2014 11:08pm
John110
Hi David, I had it sold, got messed about so I changed my mind. I'd only be back to square one and buy another and spend a fortune on it too! For those who understand, no explanation is needed...
Post #356010 6th Sep 2014 8:38am
