![]() | Home > Technical > Removing the steering wheel on a Puma |
| Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2114
Hi there!
According the workshop manual it is necessary to use the special tool: Remover, Steering Wheel (PN 211-295) to take out the piece. There is an alternative to take it out not using this tool? Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Exactly the same as Landy Andy. Cannot emphasise enough to keep the centre nut on until the wheel is loose, alternative could be a nosebleed when it lets go and smacks you on the hooter. I loosened the nut and used a rubber mallet first removal.
Thanks guys
Eduardo you're very welcome, only remove the nut totally if you have one of these handy.....
Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| tobz102 Member Since: 07 Feb 2014 Location: Atherstone Posts: 134
+1 for loosening first.
When I removed mine the first time without loosening, I also removed half my front tooth. |
Good advice and probably this special tool will be more acequible than the 211-295 Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
