Home > Technical > Lightforce 170 Striker HID switch - newbie
alexcavXS
United Kingdom 2006 Defender 90 Td5 XS CSW Java Black
Good evening all,
I'm after some advice as to what I can use to switch on my new lights for my 06 TD5 90xs.
After recently purchasing a pair of Lightforce 170s and the lightforce wiring loom (incl little black rocker switch) I am wondering if I could purchase the defender aux light (light2) switch and use this to switch the lights on and off or will it not work with the lights?
Appologies if this is a FAQ or doesn't make much sense but I am a newbie to defenders.
Any help greatly appreciated
Thanks
Alex
Post #355454 3rd Sep 2014 9:01pm
You don't have to have a switch for front mounted lights only roof lights unless you actually want one.
Post #355459 3rd Sep 2014 9:07pm
alexcavXS
I'd ideally like one really.
Post #355461 3rd Sep 2014 9:11pm
Fair enough, I use mine on main beam controlled by the stalk.
Indeed I know the switch you have in mind. Quite expensive at around £55 now I think.
Dingocroft do them iirc
Post #355466 3rd Sep 2014 9:27pm
alexcavXS
I wondered about doing the same, but I thought it'd be good to still be able to run just the normal headlights.
Yea I'm lead to believe it's expensive, I've seen them for £59 I think.
Post #355472 3rd Sep 2014 9:37pm
Likeomg
You can use the heated seat switch as a compromise (they were £14 when I got one)
Same just without the picture, I just replaced the cap with a blank
Post #355475 3rd Sep 2014 9:45pm
alexcavXS
Brilliant. Thanks for the advice chaps!
I'll post up some pictures when it's all fitted Smile
Post #355482 3rd Sep 2014 10:10pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Yes switch is expensive, had the same issue with mine. Eventually bought the correct switch from Dingo. Had Devon 4x4 do the basic wiring on the dash to a new auxiliary fuse box. I then wired the light to the fuse box.
The difficulty Is wiring the negative switced side of the switch to accessory, unless your an auto electrician !
Wiring diagram below
 2007 TD5 90 Hard Top
Post #355484 3rd Sep 2014 10:16pm
alexcavXS
That's so so helpful!! Thank you very very much!!!
Post #355494 3rd Sep 2014 10:44pm
