Home > Maintenance & Modifications > OBD2 ELM327 WiFi adaptor
Notice these on eBay, cannot complain at the price.
Does anyone have one? My main question is can they be left connected all the time or do they have to be fitted and removed as per used?
One of these: http://www.ebay.co.uk/itm/WiFi-ELM327-OBD2...3a8744ceeb
Would there be any security vulnerabilities if left installed?
Post #354470 29th Aug 2014 8:58pm
993porky
United Kingdom 2002 Defender 90 Td5 HT Baltic Blue
Daft question but what is it ?
Do you need proper diagnostic kit for it to work or does that do the diagnostic ?
Post #354483 29th Aug 2014 9:36pm
That plugs into the a Defender diagnostics port.
You can then use an IPad or iPhone app to access any DTC's and extra info. (Uses WiFi no wires)
Basically it gives you detailed information from the electronic system in a Puma Defender.
Post #354486 29th Aug 2014 9:47pm
993porky
Thanks for quick reply it is a cheap bit of kit wonder if it would work on td5
Post #354493 29th Aug 2014 10:29pm
A late TD5 maybe, I cannot be sure so can't really advise on the technicalities.
What system does the TD5 have?
Post #354502 29th Aug 2014 11:02pm
roel
Td5 is not OBD2. Big Cry Roel
2003 90 Td5 (2009-now)
Post #354519 30th Aug 2014 7:48am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Won't work on TD5.
Q: why use WiFi, isn't a Bluetooth version more useful..?
Simon
Post #354521 30th Aug 2014 8:12am
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
I'd choose a bluetooth version unless you are already using the bluetooth on your device for handsfree. I installed an ipad in the dash of my audi when i had it and had a bluetooth version plugged into the OBD port 24/7 to connect with an app to show readouts.
I'm pretty sure the OBD port is switched through the ignition, although that could differ between vehicles, so you have no worries about someone connecting to it when you have left the vehicle.
Post #354524 30th Aug 2014 8:42am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I had an odd experience with having one of these plugged in all the time. Driving along quite happily and suddenly lost all power and electrics for a second or 2 and then all back on again. Shocked Dash lights came on and temp needle went to the max and down again .. Basically looked like a reset .. Including resetting my trip. It happened a couple of times. Since I've not had it plugged in I haven't had this issue since.
Tried some cheap Bluetooth ones and had no luck .. Ie they don't work. Waiting for a gopoint bt1 to come up on fleabay. 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #354530 30th Aug 2014 9:20am
K9F
With regards to your OBD socket I would be very careful what you connect to it. The system obviously relies upon set resistances and voltage values. It could potentially have serious and expensive consequences connecting anything 'unproven and cheap and cheerful' to it as detailed by Carrotbay for example. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #354535 30th Aug 2014 9:45am
I'm not set on keeping it plugged in, so from what Carrotbay mentions I'll probably use it when not driving.
I'll give it a try when I have actually got my Defender back! Big Cry
Post #354536 30th Aug 2014 9:45am
K9F
I know it's more money but why not get a renowned reader? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #354539 30th Aug 2014 9:49am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
I use a bluetooth version with the Torque app on the phone - my expectations were pretty low when I bought it but it's been incredibly useful and is cheap enough to leave in the car without worrying about it. Have used it on a number of cars to clear fault codes. As others have said, wouldn't consider leaving it plugged in permanently.
Post #354562 30th Aug 2014 12:57pm
Defpuma
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
I bought one of these a while back.
Kept getting the MAF sensor code which i assume is related to the RAI that I fitted. I only use it every now and then to reset the engine management light which comes on occasionally. I downloaded an app on my iphone (called OBD car doctor, which is free) which then connects to the OBD sensor when plugged in. It sends out its own wifi signal somehow which then talks to the app to let you know what the fault code is and let's you clear it if it is nothing to worry about.
I wouldn't drive around with it plugged in though.
I think it cost about £8.
Post #354809 31st Aug 2014 8:46pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Used one last weekend and it caused the temp gauge to go to the top of the scale, the MIL light to come on and the engine went into limp mode. Decided that it would be better to purchase a proper product now.
Post #453307 8th Sep 2015 10:57am
