![]() | Home > Wheels & Tyres > Advice |
Do you have a lift? Fitting 20" with a profile of 60 you may find you'll need it.Searching through some of the threads your profile of 60 seems big. Have you thought about the speedo and gearing implications?
Have a play with these:- http://api.viglink.com/api/click?format=go...%3C%2FB%3E Effect on speedo: At least you shouldn't get caught speeding as it'll under read by about 10% http://tire-size-conversion.com/speedometer-calibration/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
chris d3 Member Since: 06 Apr 2010 Location: sunderland Posts: 378 ![]() ![]() ![]() |
2mph out on the bigger the same 255/55 need to no if they rub what the ride is like
PM Killer90 he used to run 20" wheels. If you go through life with your head in the sand....all people will see is an ar5e!!
