Home > My Defender > Upgrades to my Defender 110 TD5
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Well its been a while since I have posted anything about my 110 which I have had for a few years now.
This is what it looked like when i got it:
After a couple of years it looked like this:
It is now going back to being more subtle by losing the spot lights and I have swapped the front winch bumper with a Flatdog DRL bumper the Mud Terrains have also just gone in preparation for new BFG All Terrains on black powder coated boost alloys. Will update with latest pic tomorrow after a polish up. I am also looking at getting roof rack powder coated.
Thats the great thing about these though when you get bored or fancy a change they are easy to modify to suit your needs. 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #353322 23rd Aug 2014 9:25pm
TD5_dan
Sorted out the load space area and had a secure tray made for my Waeco Fridge and a storage box
Before:
After:
1960 Series 2
1972 Series 3
Post #353325 23rd Aug 2014 9:30pm
TD5_dan
This weeks job was fitting Wipac Crystals with Osram Nightbreakers and relaying the front headlights. I tried them for the first time tonight in the dark and overall it is a big improvement over standard for very little money. Also gave me opportunity to wire in the FlatDog DRL bumper
Fitted the DRL automatic switching unit to the wing beside the radiator:
Fed the wires through to the area behind the headlight in convulated tubing and run some twin core cable in tubing from the battery all the way to the front headlight as the DRL unit needs to be wired directly to the battery:
Spliced the orange wire from the switching unit into the side light circuit so the DRL's go out when the sidelights come on to keep me legal:
The loom upgrade for the headlights was only around £7 off Ebay from China, i brought 2 for that price so i had spare wiring and parts. They had wired a couple of pins wrong on the relay which i swapped and while i was at it i run 2 seperate power feeds to each relay with their own fuses. I improved the ground points aswell. Overall though the loom was a good starting point and i would have struggled to buy the bits to do it myself for that money.
Relays and fuses mounted up high on inner wing:
The power feed came off the alternator in convulated tubing to protect it
The loom run along top of radiator panel and plugged straight into back of left hand headlight with a ground on the rad panel.
Loom plugged into existing headlight plug on drivers side and taped up to protect it you can see new yellow headlight plug ready to fit:
Some tidying up of DRL wiring before rad panel goes back on:
Thats it you can now enjoy some extra lighting and also protect your headlight switch from being burnt out! 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #353331 23rd Aug 2014 9:58pm
TD5_dan
Some pics as it stands now after a good clean up, Lights have all been swapped for Wipac LED units and the reverse and fog lights have been changed for RDX units.
1960 Series 2
1972 Series 3
Post #353412 24th Aug 2014 5:03pm
TD5_dan
Mudstuff Dash
Fitted a Mudstuff dash so it went from this:
To this:
Very Happy Ive still got some switches to add but overall im really impressed with the quality and wanted something more factory looking than the raptor offering. 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #353421 24th Aug 2014 5:54pm
mk1collector
That looks so clean and tidy!!! Excellent.
Post #353422 24th Aug 2014 6:02pm
TD5_dan
Thanks mate, it don't scrub up bad for a 13 year old one. How was yours on your holiday? 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #353423 24th Aug 2014 6:06pm
mk1collector
It got us there and back but the running problem since the service is still there and more noticeable at motorway speeds Crying or Very sad
Post #353424 24th Aug 2014 6:10pm
TD5_dan
There is always something isn't there?! Sure you will get it sorted hopefully something cheap and easy to fix! 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #353427 24th Aug 2014 6:56pm
jimbob7
looks well fella,like them front led's,that can be next on mi list Thumbs Up ! Pov.spec,ftw. 2006, 110,TD5.
Post #353450 24th Aug 2014 9:55pm
TD5_dan
Thanks got lots of inspiration and help from others on here Thumbs Up I have to say I'm really impressed with the led units I had led bulbs in the existing before which had a blue tint but these are much better. My only disappointment with the wipac kit has been the relay which causes my trailer warning light to come on when I indicate. I've seen the solution is the rdx one though by the looks of it. 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #353455 24th Aug 2014 10:26pm
I.AM_a driver
Scotland 2002 Defender 90 Td5 CSW Oslo Blue
yup the RDX relay has a variable resistor which you alter to get the trailer lamp functionality back, although it can't sense the minimal resistance of LED trailer lights.
Smart looking truck you got there Very Happy Mark S
CONVOY for HEROES
www.facebook.com/convoy4heroes
www.lothian4x4response.org
Td5 90
Thread in 'My Defender' Forum
Post #353458 24th Aug 2014 10:30pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
After:
Where did you get the storage trays/boxes made..?
Simon
Post #353472 25th Aug 2014 8:25am
TD5_dan
Simon, I had them made by a company called Metallics UK
Link: http://www.metallicsuk.com/index.php?route=common/home
They custom made everything to my requirements and the finish is very good with gas strut on lid on rubber seals around the inner edges. 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #353488 25th Aug 2014 9:50am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
some nice Landyglass rear panels and do the side steps in black too... Putting Dreams on Drives at JLR Solihull..
Post #353493 25th Aug 2014 10:06am
