Home > Maintenance & Modifications > RDX LED relay it does what it says on the tin!!
gilarion
Just fitted the RDX relay from Bolt On Bits.
Since I fitted LED indicators I have struggled with several LED flasher relays including the WIPAC one and a relay from Mobile centre, but I could not get the trailer warning light to stop flashing every time I indicated without a trailer attached.
So I finally went for the RDX one, result no more trailer warning light flashing when no trailer attached, but flashes when a trailer is attached. Also a nice little clicking warning sound and indicators flashing at the right speed.
Post #353279 23rd Aug 2014 2:33pm
I've got the same no complaints. Thumbs Up
One tip though, adjust with the engine running not with just the ignition so that the voltage is higher.
This way you get the quickest possible flash rate but with the trailer light off.
If you do it with just the ignition on it'll seem right but when the motor is running the trailer light will start coming on.
Post #353282 23rd Aug 2014 3:23pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Just wish they did a 24volt version! I have the Mobilecentre one fitted at the moment and I don`t like the flash rate as it`s very slow. Also does not have the trailer light function which I want so will probably end up fitting an original Landrover flasher unit and some resistors. Crying or Very sad
Post #353310 23rd Aug 2014 7:58pm
Buccaneer
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Sadly for us 50th's owners a total b*****d to fit as we have to remove shed loads of things and skin knuckles to get to where the relay fits. The Rules:-
1 Buccaneer comes back alive.
2 Chicks dig scars.
GB260
Post #353315 23rd Aug 2014 8:39pm
Mo Murphy
Why is it more difficult ? Do you have a different dash ?
50 Shades of Pennine Grey
Post #353345 24th Aug 2014 5:43am
Buccaneer
The flasher relay is buried under the transmission tunnel behind where the other relays are and this needs to be removed for access to this one relay. The Rules:-
2 Chicks dig scars.
GB260
Post #353348 24th Aug 2014 7:15am
I have the mobilecentre relay fitted and it works flawlessly
I will be fitting LEDs to my off-road trailer
Post #353349 24th Aug 2014 7:19am
Mo Murphy
Ah, I see, that explains it then ☺
Thanks
Post #353394 24th Aug 2014 1:19pm
gilarion
Will you ned to fit load resistors to your trailer lights
The trailer must be using incandescent bulbs or LED lamps with load resistors for the Trailer light to flash. It cannot detect trailers solely on LED lamps it will make them flash ok but will not flash the trailer light as the extra load is too little to detect.
I do not know of a relay that will 'see' LED lights on a trailer and light up the warning light, although the RDX relay will flash the trailer lights it will not light up the warning light, but I suppose you could live with that.
Post #353395 24th Aug 2014 1:44pm
Your not supposed to tow with it not working though I think.
Most likely would need load resistors indeed. But depends on the resistance.
Post #353398 24th Aug 2014 3:23pm
munch90
or fit a buzzer and forget about the dash light
mine (buzzer) works with leds or bulbs (have trailers with both)
cant see the point in leds with resisters
Post #353416 24th Aug 2014 5:34pm
gilarion
I cannot see the point with resistors either nor that some people put a 20 Wat bulb into the circuit
Post #353430 24th Aug 2014 7:09pm
Tis a easy job however now that I have fitted a proper head unit and heated seats it will take a little longer to remove Thumbs Up
Post #353467 25th Aug 2014 3:31am
I was going to test first with a led tailboard
I'm not worried if the dash light illuminates
Thanks for the heads up Thumbs Up
Post #353489 25th Aug 2014 10:02am
Just follow the instructions to the T it works a treat Thumbs Up
Post #353491 25th Aug 2014 10:05am
