![]() | Home > Technical > Defender 90 (2004) TD5 - Front Hub |
| Tank Member Since: 25 Jul 2014 Location: Fife Posts: 444
Cheers Roel
Fifth , still don't know what you mean, cant see anything on the nut ? If I grab the disk, once I had tighten up the nut there seemed to be play from the swivel housing ? I assume there shouldn't and that is f'k to ? |
| Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339
if the nut looked undamaged like this
when you took it off then its not surprising it was loose - the only surprise is that the wheel hadn't fallen off The machined part should have been deformed to make contact with the machined flat on the stub axle. The play in the swivel may be able to be adjusted - there are shims under the top pin. The workshop manual tells you how, there used to be one in the galleries. |
So which way round does it go on ? With the machine part towards the stub axle ie inwards ? My nut looks just like your picture ? has it been put on back to front ?
Still confused sorry |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
Machined part outwards then when tightened up tap the thinner machined part onto the flat part of the thread on the stub so it has to push out the hammered bit before it can turn/loosen.
Oh right where the flat bit is on the washer ?
This wasn't done on mine, no wonder it was had tight ! Should have gone to the garage ! |
You've got it, it might have just had a light tap when it was done originally and the shape has been put back by the action of taking it off.
As a bit of consolation for you, I set about replacing the swivel bearings today on my NSF. This is the only wheel on my motor with the single nut/spacer set up for the wheel bearings. I have the complete service history for my motor and there is no mention of any wheel bearing changes prior to my ownership, now in its 5th year. I've replaced the OSF but that was the 2 nut and locking washer and I replaced like for like. I've had to tighten the rear wheel bearings and know they're the same. The NSF(single nut job) has never given me any reason to adjust or touch before today and when I took it apart it too was just sat there with no sign of it ever being tapped down onto the flat on the stub |
Found this on the web, think this is what it should look like ?
Click image to enlarge |
That's it
Yep and mine didn't look like that !
Duno how the wheel didn't fall off |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
That is just because the washer behind it has also a flat pieces and shouldn't be able to rotate. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18051
It's intrigues me that the WSM is very clear in stating the the stub axle should be fitted with the flat at the twelve-o'clock position, it at the top, both for the TD5 and TDCi. I have never yet come across an unmodified ex-factory vehicle which has had it fitted in this way, always just at some random position.
I don't see that it actually makes any difference except that it is possible harder to stake and unstake if not at the top. |
So to stake it I just hit it with a bit blunt instrument to bend the machined bit flat ?
Damn
What have I done wrong ???????????????? I don't have enough spline on the half shaft that stick out to get the circlip and washer on ????? What are they for ? Important ? Cheers Duncan |
| All times are GMT |
