Home > Maintenance & Modifications > Which shocks for a 90 pickup??
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
Am new to the world of 90's so need some advice. I bought a lovely 06 plate pickup last weekend and am going to start by putting new shocks on to sort out the appauling ride. I am after advice from people who have actually fitted different shocks to a 90 pick up or hard top about what is best to fit. I will be using the vehicle for farm tracks, a bit of greenlaning, road use and the odd play day so I don't need to go crazy with reservoir dampers etc but I do need a decent road ride.
I have fitted De Carbon shocks to my lifted 110 but am completely new to the 90 territory. I was really pleased with the ride quality as control from them.
Help!!
Post #34882 22nd Jun 2010 5:29pm
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
I will be doing my 07 Hardtop 90 soon as i find the ride a bit choppy on standard shocks as well
the ones i have narrowed it down to are Bilstien HD yellow shocks also i am going to fit there steering damper as well.
I fitted this setup to my 300tdi Discovery and it made i a completly different vehicle to drive.
Post #34892 22nd Jun 2010 9:16pm
Landy nut
When are you fitting them and can you please let me know feedback on how they perform and react to the road. I really need to get my ride sorted so I can get on with the other non essential bits!!!
Where did you order them from and what was the best price you found?
I would be interested to hear from anyone else who has experiene from other manufacturers and also anyone who has any comparative experience.
Post #34897 22nd Jun 2010 9:47pm
Landy nut
Is there anyone else out there who has fitted different shocks to a 90 and got a much improved ride?
Post #35265 28th Jun 2010 6:20pm
landy andy
I have fitted Koni adjustable shocks to mine two years ago, and find them very good. My set up is more road based, as it is my work van, and for my overlanding with roof tent, but it does a LOT of off road stuff and does well, even tho I have the anti roll bars fitted.
One of the 90's that I lane with have just had a VERY VERY nice set from Gwyn Lewis, and it is top notch. Slight lift but MASSIVE drop out so never looses traction. About £1000 tho. Gwyn supplies the parts you fit he then checks over and adjust for you.
This is quite apealing to me, but I think it will involve loosing my anti roll bar!!!!!!!!!!!!!!!!!!!!!!!
Hope this is some help
Andy
Post #35284 28th Jun 2010 9:37pm
I suspect that the reason your 90 has an appauling ride, is that it's a pickup, so not much weight over the rear axle, yet its got the suspension capable of carrying nigh on a ton of weight.
IF you loaded the back of your 90 up things would improve dramatically, that, or fit softer springs, something like a rangerover classic rear spring.
I usually run OME dampers, and sometimes OME springs too, these have always served me well and i like the way the vehicle handles on them.
Post #35731 7th Jul 2010 7:46am
K9F
Landy nut,
If you do a search under 'shocks' there are 65 threads to chose from, what you seek must be in there somewhere!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #35735 7th Jul 2010 8:12am
MK
All I can say (I have a 110") Rough Country are softer than OE and cheap. I have Rancho which are adjustable and about the double of RCountry. Puma 110" SW
Post #35763 7th Jul 2010 12:44pm
