Home > Td5 > Boost Gauge Installation
NRodrigues
Portugal 2001 Defender 90 Td5 ST Aintree Green
Hello!!!
I'm installing a Boost gauge on my TD5, but i've some doubt which is the tube to install the "T". Should i use this thin tube of the wastegate???
Post #351790 15th Aug 2014 4:49pm
silky16v
England 2001 Defender 90 Td5 X-Tech LE Blenheim Silver
You should ideally tap the inlet manifold as you want the boost pressure after it's passed through the intercooler
Post #352616 19th Aug 2014 10:20pm
I think the boost pressure is available via the engine diagnostics so for example an obd reader could read it from the ecu
Post #352638 20th Aug 2014 6:30am
Stue5
Italy 2005 Defender 110 Td5 USW Alpine White
I don't think the td5 defenders were Obd2 protocol compliant as being a duel purpose vehicle.(need nano com or some other special gizmo). But the pumas are. If running a boost box it would give a false reading. I have mine in the top of the inlet manifold at where the egr used to enter.
Sorry if I got this wrong , please correct me! Whistle Thud Range Rover p38 4.6 99 lpg(gone Sad )
Post #352677 20th Aug 2014 10:46am
excossack
Have you checked Boost gauge reading with a reading from the ECU via a Nanocom etc? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #352679 20th Aug 2014 10:49am
Stue5
I tried with a generic eBay obd2 reader, which sort of worked on the p38 and quite well on other cars, but it did not talk to the 2005 td5. Then I read some where (cannot remember) about the defenders not needing to comply.
Nano com wise I have never played with one. Range Rover p38 4.6 99 lpg(gone Sad )
Post #352722 20th Aug 2014 3:24pm
silky16v
generic code readers won't work
so either fit a EGR delete and drill tap this for 1/8pt nipple take off or remove inlet manifold (clean it while its off) and do the same you can then fit any generic boost gauge
Post #352724 20th Aug 2014 3:33pm
Stue5
I have seen the EGR blank kits with the boost gauge pipe welded on already, i would have gone for one of those had i seen one earlier.
You jogged my memory silky16v Thumbs Up
After a bit of hunting,
http://www.egrvalve.co.uk/index.php?page=l...d5-egr-kit Range Rover p38 4.6 99 lpg(gone Sad )
Post #352735 20th Aug 2014 4:53pm
bob neville
^^^ That is exactly waht I have fitted to my TD5, made by Allard Engineering.
2013 Defender 90 CSW - sold
Post #352736 20th Aug 2014 4:56pm
