![]() | Home > Puma (Tdci) > 20k and the faults so far.... |
Plodster Member Since: 24 Mar 2013 Location: UK Posts: 22 ![]() ![]() |
So my 2.2 90 HT has reached 20k this month and I'd like to say it's been trouble-free, but I would be lying!
Replaced and repaired so far: EGR Rear callipers PAS pump & belt tensioner Clutch Gearbox selector bushes Gear stick and selector Windscreen seal Bulkhead seal Coolant pressure cap Swivel sea Handbrake cable tensioner Door seals Window mechanism Door locks Plus of course the obligatory intercooler pipe recalls and ECU updates! Suspect the next item will be DPF related given the current issues and wondering what the next 20k will bring! Hmmmm, thats not mud.... Current: Defender 110 HD Utility (Special Vehicles) Freelander 2 HSE BMW E23 735i Ex: 2013 Defender 90 2.2 1998 Discovery 300TDi 1972 Series II 2.25 1980 Series III 2.25 |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 419 ![]() ![]() ![]() |
Oh my god. That's awful. Yours must have been built on a Friday afternoon!
why were the calipers replaced with less then 20k
pjw4233 Member Since: 30 Nov 2009 Location: Lake District & Cheshire Posts: 273 ![]() ![]() ![]() |
Had mine three years, covered 66k miles, following parts replaced:
Wiper blades Side light bulb A wheel bearing Coolant pressure cap |
It really is horrible how inconsistent they are with build "quality" - never ceases to amaze me. I wonder if the new one will be any better... Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
aage Member Since: 26 Jul 2012 Location: Iceland Posts: 44 ![]() ![]() ![]() |
My 2011 at 17.000 miles
Failures so far : One wheel bearing seal ( changed it myself , 1hr job ) Driver seat foam ( fixed it myself ) One shock rubber bushing ( Lower rear , fixed it myself 5min Job ) Nothing else and I love this car ![]() |
All down to not being built by robots but on a production line manned by humans using processes rhat have changed little over the decades. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
And we still love them! Hmmmm, thats not mud....
caterham6 Member Since: 18 May 2014 Location: Manchester Posts: 47 ![]() ![]() ![]() |
Its only "Money"
That's what the warranty is for! Hmmmm, thats not mud....
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 ![]() ![]() |
Plodster, look at it like at least your dealer is willing to do such work. It would not surprise me dealers use warranty to keep the workshop turning when times are quiet, or they have a special like to you and are keen to have your truck 100%. It could just be being hand made you and I received cars made on a day no one was interested. I was amazed how much stuff went into mine in the first 100 000. ECU, transfer box, EGR, starter motor, an ignition, two immobilisers, key barrel, couple clutches, couple door locks, door rubbers, suspension rubbers, gear box robbers, floor matt, and a fair bit more just cant recall really. Odly enough after the 3 years was up it's been trouble free seemingly having been finished off by the dealer and reliable at last.
It can be frustrating, but as long as you have a loan car, who cares what LR do to it under warranty. I'm pretty confident there was no profit left on mine for them. I didn't ever drive a hard line, just noticed stuff and they went nuts. Still I'll probably by another LR as I am impressed with the warranty. Other marks have similar issues, but you do hear getting warranty is like blood from a stone. At least we find it amusing to some degree. My Defender and travels Last edited by newhue on 19th Aug 2014 12:25pm. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17823 ![]() ![]() ![]() |
This thread made me think about mine, a 2007 2.4 110 now at 7 years and 150k miles:-
Parts replaced due to failures/malfunctions- Front diff Front halfshafts and drive flanges ROS hub oil seal Rear halfshafts and drive flanges (twice) Clutch assy (now on fourth clutch) Rear propshaft UJs Transfer box rear oil seal and handbrake shoes (twice) Transfer box Dip/indicator switch Light switch Wiper park switch Windscreen (due to large rock, not LR's fault!) Front disks and calipers (wear and tear, not really a defect) Volume control valve Fuel tank breather Driver side seat base foam Coolant pressure cap Sump pan Intercooler pipe In addition it has had regular service parts and consumables such as brake pads. It is on its second set of tyres (I love BFG Muds, 100k miles from a set)! On the "to do" list at the moment: the ROS brake is dragging and so I probably need new rear calipers, the rear disks are about due for replacement, the weather strips on all four doors need replacing and the radiator is weeping and needs replacement. Is this bad? I don't really think so. The vehicle works hard and has done a high mileage, and I love it to bits (at least most of the time). It still puts a smile on my face. By comparison at this age and mileage my Disco 2 had had one clutch changed (due to DMF judder not wear) and that was all. (Editted to add a few things I'd forgotten). |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
I guess you don't name it right. These are all not faults, it is just socializing and selecting it's driver by getting you used to repair, care and maintenance. Would you like a car, which accepts the worst lunatic driving it? Never forget: cars have owner, Landrover have field service personnel.
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
Mine 2009 MY and has done 51k miles. Replaced following.
*front differential *front differential oil seal *clutch, pressure plate *Four Injector bottom washers *front and rear brake pads *front wipers. *intercooler hose It's not a Toyota. It's a Landrover so no surprise. But I am enjoying it! Last edited by dilukabey on 21st Aug 2014 4:48pm. Edited 1 time in total |
