![]() | Home > Technical > Defender 90 - Stupid Question |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
as far as I know you can only buy the whole thing , and there a pig to fit
but I have always managed to put the pipe bit in a vice and pull the outer bit off and push it on to the stub sticking out of your bulkhead could use small amount of glue to stick it more permanent |
| Tank Member Since: 25 Jul 2014 Location: Fife Posts: 444
Cheers Munch90
So buy a new one and pull the outer bit off ? Duncan |
Which one do I buy ?
| Simon27 Member Since: 30 Oct 2012 Location: East Lothian Posts: 131
I recently lost mine and bought this one:
http://www.ebay.co.uk/itm/Landrover-Defend...33636aa9e0 Clamp the threaded end in a vice, then knocked the end off with a mallet and block of wood. Then needs a really good shove to fit over the existing pipe bit. |
Cheers , will try that as fitting new one seems to be a pig from what I can see
Defender ownership joys ! |
| Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280
The fitting is not too bad... takes a little bit of time and you need to dismantle the dash, but it is easy enough. (and when you have it opened up there is a multitude of other things that you can do too)
When you are at it 'upgrade' and fit a second washer, then you will have 4 jets and a screen that gets cleaned much better. You will see there are 3 holes on the bulkead, your existing washer is in the middle one, use the other 2 for your new washers and plug the middle one with a gromit. All you need is a t-piece and small length of washer tubing which you can get from a motor factor .... or Hellfrauds! Well worth doing! |
Cheers Mean Green.
Gona do a quick fix at the moment and come back to do a better job later. Funny thing is I have to jets at the moment, one on top of the other ? Only the bottom ones works though. I must have a weird Landy Cheers |
| JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532
I see you're a Fifer so go to Mike Aitken 4x4 in Ladybank. You'll not get better! 01337 831114
Come to think of it, it would be an ideal time to convert the washers from single to twin head which is a whole lot better, especially if you go playing at Glentarkie!
Mean Green.
Took the top of the dash off and got to it. You do need small hand (which I don't have) nut managed eventually ! All done and dash back together ! Cheers for the advice. Duncan |
No problem .. that's what these forums are for
Did you go for the upgrade with the extra double jet? It makes a big difference. It was a long time ago that I changed mine, but I seem to remember that you get better access by taking the stereo fascia and switch panel off, you can then gain access to the nut (I think! |
Nope just went for the cheap £2.39 replacement. Does the job
| All times are GMT |
