newhue
Before a trip I changed my outer seals in the hubs. I then had a similar sound but from the front. Turns out I had not seated the seals deep enough into the hub. The squeal was the seal rubbing on the stub axel.
The stub axel lock nut was firm, no movement in wheel bearings, and car drove as it should but just squeaked. I did 20K Km and ate a set of pads which brought about the second round of attention.
New seals, and seated the 4 or 5mm required depth into the hub and the squeak has gone. one possibility. My Defender and travels
16th Aug 2014 10:38pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
