![]() | Home > Td5 > TD5 Fuel pump Death |
Check the relay with a known good one or just get a new one. Double check the earths in the seat box, it's a damn site easier to get those basics out of the way before dropping the tank. Personally I would go for the top approach to the pump, i.e. cut an access hole in the floor, that's what I did when I changed my pump, the tank and everything stays undisturbed, access to the pump in mine would only take 10minutes and most of that is emptying the junk out from the back of the motor!
You should have two yellow relays next to each other. Try swapping them.
The fuel pump relay is very voltage sensitive. Hold your fingrt on it while cranking to see if it vibrates. If it does check your earth connections. I ultimately cured mine by fitting a new battery. ![]() |
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 ![]() ![]() ![]() |
Thank you everyone, I will be back at her today see if I can rectify this.
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 242 ![]() ![]() |
Also agree with the cutting of the floor method
Done that on my TD5 Otherwise it's a nightmare, especially with anti-roll bars that you can't get off ![]() |
Ok, ive now discovered the pump is good, ive traced continuity from the engine bay right back to the fuel pump all is good there, now when i get to the relay behind the gear shifter there is a green relay that looks as if the socket has had some heat and if i bridge the pins 30 and 87 the fuel pump comes to life..
How do i test the relay as i dont have a spare one of these! |
Swop it for something you don't need for now, heater fan relay or spotlight one if you have them fitted.
Thanks for the Replies, Im completely lost now.
1) All wiring front to back is good for continuity 2) Fuel pump is good, tested from green relay by gear shifter. 3) Checked relays with 12v supply and multimeter and they are all good 4) all fuses are good And yet i still have no fuel pump when i turn the ignition on....could it be my ECU or even ignition? |
I'd be looking for one of those obscure fuses that crop up in the wiring diagrams or not! Look through all the fuse boxes.
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
If it's turning over, but not firing - faulty crank sensor?
Is the EML lit? Has it been plugged in to check for faults? It wasn't me! |
Have you checked the relay while cranking? The voltage may not be high enough.
Ruari Member Since: 10 Dec 2013 Location: Ayrshire Posts: 50 ![]() ![]() |
Do you know if the + supply from the ecu to the relay is live when cranking?
If you solder a wire onto a pin, you can pierce the wires at the ecu to take the readings. I imagine it is 12v as it is a relay your turning on. There shouldn't be a fuse inbetween ecu wire and relay. If there is no crank reading, the fuel pump still runs. (or at least when my ecu died and indicated no Crank the fuel pump still ran.) |
I haven't checked the + from the ECU yet, as im getting all the relays standing to attention when the key is inserted, just for the life of me the pump isnt firing up, but i know its working. what is baffling is the way it stopped, a week earlier it did the same thing and after attempting it a couple times i took the key out put it back in and it worked, then she was fine until friday when the same happened and has never come back..
trying to get my hand on a Diagnostic machine is proving harder then i thought, so i think a purchase will have to be made, can anyone tell me a good inexpensive unit to buy..
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Have you tried Starthearn Engineering for a diagnostic scan? Not 100% sure what they charge
Cheers John 2014 110 2.2TDCi XS Station wagon - GONE 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE |
